Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water will not come into the ice maker and the filter needs changing. Even though the filter needed changing before, water has never stopped coming into the ice maker. The line seems to be clear. Any suggestions?
  • Whirlpool Master
  • 1,606 Answers
Replace the water inlet valve after making sure the tube which fills the icemaker is not frozen . If it is , replace the valve anyway . The valve is the piece which connects to the line to the wall on fridge .
Posted on Aug 04, 2009
Ice maker not working
what was reset button for? is it something like defrost the unit when press. you said that it is already replaced then likely your problem is with the unit thermostat all ref unit has it and most likely to fail overtime, it is also possible that there is leak on the sealing doors which makes your ice melts faster when the motor stop pumping freon
Feb 28, 2014 | Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker stopped making ice
Here is a check list to use to verify ice maker is good or bad or if something else is causing the problem.
1) Has the water filter been changed recently, or does it need to be changed? The filter being old can cause a reduction on water and lower performance of anything else that requires water.
2) Check the temperature in the freezer. Even though things are frozen in there, the ice maker requires that the temperature be at least 10 degrees F to even cycle. Ideal would be around the 0 degree mark.
3) Check the fill tube where water comes into the ice maker. From time to time this will get blocked due to water freezing in the tube itself.
********* If the first three checks all pass, either the water valve is bad and not allowing water to come to the ice maker, or the ice maker itself is not calling for water **********
Depending on the age of the machine it might not be a bad idea to change the water valve and the ice maker together.
May 30, 2012 | Frigidaire Refrigerators
I have the Whirlpool ED5FHAXV side-by-side refrigerator. It has stopped dispensing water but the ice maker is still producing ice (very odd as they are from the same supply). Even though I was 99% it...
Same supply from your house and the the water valve on the refrigerator splits the supply. It could be the ice maker, the freezer getting warmer and not reaching the cold point for the ice maker to make ice or the a faulty water valve
Dec 23, 2017 | Refrigerators
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
Icemaker not making ice
If water is also not com out of dispenser then filter should be changed. If water dispenses but ice ice is not being made, the sensor arm or infrared sensor may be stuck or blocked. If sensor is OK then ice maker needs service.
Aug 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Changed filter water leaking out of ice maker even when shut off
if u have changed the filter and it wasnt letting water though before you changed it, then some foreign material has come out of the filter and has wedged its self under the plunger of the water solenoid holding it open
Apr 28, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Apr 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
171 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
