Question about Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking
Non stop ignitor clicking
Wolf 6 burner stove and a Wolf single burner Wok stove have non stop ignitor clicking. Its approx 3 yr old stoves. Any ideas as how to fix them ?
    President:
  • 3,433 Answers
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Posted on Jul 29, 2009
The toast button does not work properly anymore, guessing there is something wrong with the contact?
My toast button did that for a while then got better. Also, try holding the button in for a few seconds instead of a fast hit.
Jan 27, 2012 | Krups FBC2 1600 Watts Toaster Oven with...
The oven turns on and works fine but I'm unable to turn it off. i have to go flip the breaker to turn it off. The clock does not appear to be right up against the screen, at times temp/clock fades in and...
If your unit is already old enough, I think it will need to replace many parts. So it is worth buying a new one than to repair it because many parts will be replaced soon. I hope I give you some idea.
Mar 21, 2011 | Magic Chef Toaster Ovens
I just moved in my condo with a magic chef gas stove/oven without a manual. I tried to use the broiler but I can't seem to make it start after pressing the button "broil". It is about 10 or 11...
Hello Bocsabh,
The model number will either be inside the door of the oven on the face usually and/or is located at the rear/back of the item. There should me a model and serial number listed on the plate. Once this information is found it will be alot esier to help you with your current problem.
Please post back to this thread and I will be glad to help you.
Thank you for chosing FixYa.com
Justin
Mar 09, 2011 | Magic Chef Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    How to set the clock on Nardi built-in stove (model FE46?) Thanks.
    There are 6 push buttons, the two on the right have a plus and a minus sign on them. Just use these to set the clock.
    May 11, 2010 | Toaster Ovens
    Need old West Bend Serving Oven -bun warmer- directions
    I have one of those that I got as a wedding gift from my parents in 1975. They were popular then. My mother had always come out with nicely warmed buns, but when my wife and I tried to use ours, our buns were soggy--from too much water, I guess.You have to use it on top of the stove, not in the oven. Try putting in about a half-inch of water and put in the middle piece. If it floats, then you have too much water. Put the buns inside, place the lid on, and put it on low heat for 2-3 minutes. You can regulate how soft or crisp the bun would be by opening the steam vent for more crispy bread, or closing it for it to be more moist. You can experiment with it, but yes, you DO need to use it on TOP of the stove.~ Barry
    Apr 23, 2010 | Toaster Ovens
    We need to purchase a broil element for a wolf Gang Puck Bistro oven.(counter top model # BT0BR0050) How would I obtain this part?
    There are any number of resources on the Internet that may have this part, although it may be that the manufacturer of the oven made this a non-replaceable part.
    In searching the WP website, they don't offer the element for aBT0BR0040 , so unlikely they ever provided one for the BT0BR0050 . Not surprising with these perceived high quality/low cost built appliances.
    The only thing else I would suggest is to see if you can even get the old element out. If you can, then there might be a chance.
    Dec 16, 2009 | Toaster Ovens
    Wolf 4 burner stove developed a non stop ignitor clicking
    If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
    Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Igniter on Wolf Stove clicks continuosly
    Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
    Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Hot plate not working
    Check the non working plate element for continuity - if open replace it. Otherwise the switch is bogus.
    Sep 04, 2017 | Euro-Pro EP278 Bravetti Platinum 1500...
    Wolfgang Puck BTOBR0040 Toaster Oven with Convection Cooking Logo
    715 people viewed this question
    Top Wolfgang Puck Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Wolfgang Puck Toaster Oven Expert? Answer questions, earn points and help others
