Question about Ritchie F 82 Voyager Compass
How to calibrate a marine compass - Ritchie F 82 Voyager Compass
    President:
  • 1,273 Answers
You must have a known bearing. This can be a lot line, or a compass rose near a yacht club (usually in the water). Lot lines are handy if you can find one that has a N-S line, as it is based on the magnetic lines of declination for your area. Compass roses are fine, and based on the same magnetic lines, but tuning a compass on a moving boat isn't for everyone. They're really more for checking than setting a compass. Your best bet is to find something that goes true north, and then get on this line.
Best 'o luck --W/D--
Posted on Jul 29, 2009
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
How to "Turn" a Centrios digital compass mod. 63-8162
It is a fun thing calibrating a vehicle compass. Find a large EMPTY car parking lot. Press the Calibration buttons and drive in 10 tight circles clockwise and then 10 tight circles anticlockwise. The light on my compass flashes as you start the circles.
May 31, 2016 | Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous Vous
Tp 30 keeps failing the calibration. Everything else seems to work fine. Tried numerous times using the instructions, doing the slow circles but each time it fails. I believe the internal flux gate compass...
I had the same issue.I opened up the TP30 to find that the wires from the compass to the circuit board had corroded and snapped.Trying to source a new compass unit now.Anyone know if they are the same as the new TP32?
Sep 18, 2010 | Simrad Tp22 Tiller Pilot Up To 36'
We have a Raymarine ST8001 autopilot system that we are unable to get throught the calibration mode to set deviation. Our boat dealer mounted the fluxgate compass within 18" of the emgine which was too...
compass needles are affected by iron objects and can also be affected by field magnetism generated by current flowing through a wire .Bilge pumps , winch motors are heavy current drawers and they could affect the compass operation
while the voltage is low the field of the magnetism around the wire can influence the compass heading so check for any electronic apparatus wiring close to the unit ( radio , radar etc
it may be necessary to run the powers wires in an insulated sheath ( like coaxial cable or other insulated power cables) around sensitive equipment
talk with marine equipment installers to get better ideas as to prevent interference with the compass
Apr 04, 2017 | Raymarine Fluxgate Compass Module
I have 2002 Yukpn Denali XL. There is a OC code that appears in the rear view. What is the cause of this and how can I fix it?
The "OC" indicates your compass is "Out of Calibration". Below is the proceedure to recalibrate your compass.
Compass Calibration
The compass may need calibration if:
 After five seconds, the display does not show a
compass heading (N for North, for example), there
may be a strong magnetic field interfering with the
compass. Such interference may be caused by a
magnetic antenna mount, magnetic note pad holder
or a similar magnetic item.
 The compass does not display the correct heading
and the compass zone variance is set correctly.
In order to calibrate, the letters CAL must be displayed
in the mirror compass windows. If CAL is not
displayed, push in the COMP button for approximately
eight seconds or until the letters CAL are displayed.
The compass can be calibrated in one of two ways:
 Drive the vehicle in circles at 5 mph (8 km/h) or less
until the display reads a direction, or
 drive the vehicle on your everyday routine and after
several turns the compass will become calibrated and
will display a direction.
Good luck.
Oct 23, 2009 | 2003 GMC Yukon XL
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
May 11, 2008 | EW3100 Radar Detector
Ritchie F 82 Voyager Compass Logo
745 people viewed this question
Top Ritchie Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Ritchie Boating Expert? Answer questions, earn points and help others
