Question about NEC Office Equipment & Supplies
Need to replace drum?
Copier - NEC FN-117
Display shows ''change PC drum''. What is the part number for this? Where can this be ordered?
  • Ukap Jul 29, 2009
    hoto I re-set so message does not show?
  • NEC Master
  • 643 Answers
Since drum is a life span part, once certain counter is reach, message will pop out. Well, if the machine is running in good condition, just ignore it.
Posted on Jul 29, 2009
Konica Minolta fn 117 password
Sir /Man, FN-117 is a Finisher (Does the hole punching and stapling if those options are available) it does not have a password What is the model of the copier? Do you want the Admin Password or the Service Mode password?
Sep 28, 2014 | Konica Minolta bizhub Office Equipment &...
How to change from ºF to ºC on the UMC-117?
According to the 2012 manual, 'the LED display only shows F.'
Bottom page 65. Yet the F temperatures are also shown as C in the manual.
http://waterheatertimer.org/pdf/How-to-set-Rheem-tankless-temperature.pdf
You probably have different model, or older model?.?
Older manual (page 15) shows same temperature range with both F and C, but typical of Rheem, the manual is totally vague about settings and say that qualified tech needed to adjust temps beyond factory default range (with no mention of display showing C) ... which is safeguard since the damg product cannot always heat water fast enough to reach higher set points above 120F.
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
Call Rheem 800-432-8373 and give your product serial number and model number located on side of unit, and ask them.
Don't forget to keep the product maintained to avoid common error codes.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 28, 2012 | Rheem Tankless Water Heater Main Remote...
My keyboard shows 6ther for other and 25ng for king. get the right lettering only if i press the fn key all the time. pls help
Looks like you have accidently activated the "Number Lock". Press the Fn key, and whichever key has "NumLk" written on it, in blue.
Jul 23, 2011 | NEC Versa VX Notebook
How can I reset the copier canon NP 6412 shows the message CC on display?
CC means you will have to replaced your drum unit. The part number is F43-5411-700. About $150.00
There is a chip in the unit that records the number of copies run. You will either have to have the drum unit rebuilt and a new chip installed or just order in a new drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 19, 2010 | Office Equipment & Supplies
Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Oct 16, 2009 | Sharp AL 1631 Copier
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Changed the drum, now power will not come on. help!
You have to go to the display and let the copier know you changed the drum ther is a code number you enter not sure for this model
If power does not come on you have not seated the drum or any comonents (there are safety switches in doors and corona ara and fuser area re open and close again
you should get a display
Dec 15, 2008 | Sharp AL-1641CS Laser Digital Copier
Develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
Mar 13, 2008 | Konica Minolta Di1610 Copier
I receiver error number E000067-0110
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
Dec 31, 2007 | Canon imageRUNNER C3170U Color Copier
275 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
