Question about Canon EOS-10D Digital Camera
Canon 10d won't turn on
My 10d went dead last weekend while i was using it. It gave no indication of a low battery. But i figured that was the problem. I recharged the battery to its fullest. And my camera still won't turn on. it hasn't been mishandled or anything like that. I'm thinking the coin size battery on the bottom of the camera might have to be replaced. Any ideas?
  • photo13 Dec 18, 2007
    i've got the same problem though i did replace the smaller battery and i've still got a camera that won't turn on.
  • 3sharples Dec 06, 2008
    I have the same problem after changing both batteries and checking all connections. The only advice I received from Canon was to try cleaning the battery contact points with an eraser. I tried this and still had no luck. The last remaining alternative is to return the camera to Canon and have them perform an inspection and offer a quote on how much they will charge to repair the camera.
Well got a little advice from a friend and here is what he suggested the lens might not be on all the way so try taking it off and putting it back on as stupid as this sounds it actually worked when i did it on mine also even though you've probably done it already clean the battery's contacts and the ones in the camera and hopefully that's all the bigger the problem is. good luck
Posted on Jan 02, 2008
Battery door
To purchase a battery door for your D10, go to eBay and search for "10D battery door." You will see several for sale and they run around $7.00.
Hope that helps,
Jan 07, 2014 | Canon EOS 10D 35mm SLR Camera
I have a canon 10D that is getting an "error 99".
You could've used a non-compatible lens or the contacts are dirty. Turn the camera off then use a clean micro fiber cloth or pencil eraser to clean the contacts.
Dec 17, 2010 | Canon EOS-10D Digital Camera
My Canon 10D will not Power On. Do I need the original battery ? Currently I have A battery from my Canon 30D in the 10D.
According to Canon, the battery should work in either camera. Does the battery work in the other camera but not in the 10D?
Oct 01, 2010 | Canon EOS-10D Digital Camera
I have a 10d digital camera. battery gos dead after shooting 15+
Try cleaning your battery terminals. You can use a little rubbing alcohol on a q-tip. If you are still having issues then you will need to get another battery as that battery is shot
May 27, 2010 | Canon EOS-10D Digital Camera
It dosent turn on
i have the same problem. i bought new rechargeable batteries and they went dead really fast and then i put some new batteries in and i took like 5 pics and then the battery indicator said the battery is low. i dont get it whats going on with this camera.
Jan 05, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
10D Canon SLR can't start up
Well replace it by all means - what does the Manual have to say about this particular battery It is usual for a full manual to be on a PDF file on the software disk - have you checked this out? If all else fails- Canon Technical Support is the next stop
May 30, 2007 | Canon EOS-10D Digital Camera
Battery Problems Canon eos 10D
My battery works for weeks. It might be a problem with the camera. Could it be the contact points in the camera?
Nov 28, 2006 | Canon EOS-10D Digital Camera
*istD battery problem
Battery charge indicators don't measure actual charge but voltage because there is no cost-efficient method to measure battey charge directly. Instead, batteries are designed so that voltage goes down with charge. Now, the difficult thing is that not all batteries behave in the same manner. It is actually very hard to predict how a battery menufactured by xyz behaves. I would guess that Pentax engineers did not have Energizer AA's in their mind when they defined the voltage alert level. I would suspect that the battery status indicator is calibrated for the CR-V3 batteries that were included with the camera body, or something else. Only wild guesses above... And yes, I have encountered weird inidicator behavior with AA batteries, too. But not with CR-V3. I bet your mobile phone battery indicator plays tricks, too.
Sep 08, 2005 | Pentax *ist D Digital Camera
Canon EOS-10D Digital Camera Logo
478 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
