Question about Metra 95 96 Chevy Truck
Truck hesitates my 1996 chevy tahoe pulls like it,s straining ,then all of a sudden it takes off fast and runs fine, it seems to do this when i pull off or go into passing gear .it only does this for about3 seconds then like i said it takes off and runs normal
  • 631 Answers
Have you changed your fuel filter? Are you sure your don't have a bad plug or wire? Is it fuel injected? Checked fuel pressure?
Posted on Jul 29, 2009
94 gmc 350 fuel injected hesitates when you step on it and backfire thru the tbi
Posted on Aug 18, 2009
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
I have a 1996 mercury sable with the 24 valve dohc 3.0liter v6. And in having charging issues. Sometimes it will charge fine and suddenly, without warning, it wont and the battery will drain fast. I...
You need a new alternator it is what keeps your car running after you start it. If it goes oyt the car runs on the battery and the battery isn't made to run a car for very long i would also have the battery tested cause running them down can ruin them.
Feb 14, 2015 | Mercury Cars & Trucks
My 2007 chevy tahoe has been having this problem where it vibrates while driving on the highway, its so bad that you need to pull over and after you pull over for a few minutes and then drive again it...
You need to have the front end and frame inspected for worn damaged parts, do not keep driving this vehicle or a full on failure will occur with the resulting loss of control and possible crash.
Jun 24, 2017 | 2007 Chevrolet Tahoe
1996 Tahoe 4x4 5.7 Vortec dies when I turn the steering wheel periodically, when I start up and pull into the street, then will start up again and then dies, or if I get gas, and pull out and turn wheel it...
The 1990's chevy trucks(all of them) had fuel pump and grounding problems:
1. Check the fuel pump ground strap next to the gas tank as it could be broken from the connector or just loose.
2. Have a fuel pressure test done on the fuel lines at the engine top. (Note: if there isn't enough fuel pressure, replace the fuel pump.)
Oct 27, 2017 | 2001 Chevrolet Tahoe
1996 tahoe bangs gears after short drives on warm days
check your rear brake shoes if you had them changed recently they may not have been adjusted properly and that sometimes will cause that and also check the rear diff yoke where the driveshaft goes insometimes it get gear oil on it and harder for it turn. i would try these hints first before i take to shop
May 29, 2009 | 1996 Chevrolet Tahoe
1996 Chevy Tahoe Back Seat
There sould be straps on the sides of the seat back rest. Pull on them to release the latch allowing you to lower them
Jan 31, 2009 | 1996 Chevrolet Tahoe
1996 Chevy Tahoe with Transmission issues
Hello;
The ECM is located inside your passenger kick panel. The codes that your friend pulled relate to the drivetrain portion of the ECM. The controls and solenoids that are causing your shudder are inside the transmission in the valve body. The TCC is probably at fault and locked on. Hope this clears things up. Let me know if you need more help.
Thanks;
Rich
RPM Northwest
Jan 27, 2009 | 1996 Chevrolet Tahoe
Metra 95 96 Chevy Truck Logo
374 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
