Part model # PN51E440A2FXA VERSION TT04
SOURCE: 42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
SOURCE: Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Hi, my 42" LG TV displays a black vertical line to
The so called plastic strip is not plastic, it is call Flexible Printed circuit board made from KAPTON, they are not soldered on to the LCD panel but they are ultrasonic welded on, it is obviously that people that tell you to resolder the connection never senn or work on the LCD panel before.
I would try reseating the ribbon cables between the T-CON board and the LCD panel first. Worst case will be bad LCD panel.
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
