Question about Gateway MT6840 Notebook
Power port for gateway MT6840
The power cord port won't charge the laptop. I wanted to know how to take the back of the computer off to see and repair the port.
  • 4 Answers
First easy check is to stick a toothpick into the jack to see if the middle pin is loose. If it's not loose, try another power adapter to check just incase. If you dont have one ask around to borrow a universal one. Dont jiggle and wiggle the plug with the power plugged in if it is loose because i've seen shorts happen.
usually plugs are mounted onto the mainboard. To get to the main board, you'd have to take apart everything because everything attatches to the main board. The case, keyboard, heatsinks, speakers, and so on must come off before you'll be able to see the power jack. With parts and labor, it comes close to a new laptop.
Posted on Jul 29, 2009
Gateway MT6840 won't power up
before checking ur mother board check for ur operating system.
Mar 08, 2012 | Gateway MT6840 Notebook
Is there a docking station for my mt6840 gateway computer?
I do not believe there is a docking station for that model. But... Try pulling out the battery. Then plug in the power supply and see if you can get it to power on. If so wiggle the plug and see if it shuts off. If either if those are true, en you most likely need your DC Jack replaced. You would want to take it to a laptop repair shop. It is usually $20 for the part and around 1.5 - 2 hours labor for the repair. Requires pulling out the motherboard and desoldering the old jack. And soldering in a new one. No fun
Dec 12, 2011 | Gateway MT6840 Notebook
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
My gateway mt6840 does not read my new battery
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Jun 02, 2010 | Gateway MT6840 Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Gateway mt6840 new battery will not charge. New charger too. Bad charging port? Bad charger board?
check the connection between the battery and the unit and clean them good try to use elctronic cleaner
Sep 08, 2009 | Gateway MT6840 Notebook
Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
Aug 03, 2009 | Gateway MT6840 Notebook
Laptop not charging even when plugged in- battery or power supply
Sounds like you have a bad power jack. Broken solder connection on circuit board. Is it loose when you plug it in the back of the laptop?
If so that is what it is, seek professional repair as it is not a repair for the novice!
Jul 05, 2009 | Gateway Computers & Internet
Gateway solo mt6840 power input is not working
I had the same exact problem, the computer techs I talked to all said it was either the DC Jack or the Motherboard. They will need to open your computer to check this out and they usually charge to do this. I had the DC Jack replaced and still had the same problem so their next suggestion was to get a new Motherboard which can set you back quite a bit. Try to find a Computer repair shop who will give you an estimate at a minimum to no charge, also ask if they are able to fix the Motherboard without totally replacing it if this is the problem. This will most likely be at half the cost of a new Motherboard. My computer was fixed for a total of $220, that was $150 for a Motherboard repair and about $50 for the DC Jack repair. The only drawback was the company ended up damaging the body of my computer and won't own up to it. Whatever you do, don't send it to Pell Technology and get it done in the near vicinity. Also take pictures of your computer before you leave it with any computer repair shop.
Apr 09, 2009 | Gateway MT6840 Notebook
Gateway MT6840 Notebook Logo
508 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
