Air condtioner not blowing enough cold air and water is dripping from the back of the air conditioner. Please help.
    Sergeant:
    Champion:
  • 232 Answers
The coil is probably frozen hense the low airflow. This is caused by dirty filter, dirty coil or low on freon
Posted on Sep 13, 2009
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Dripping water from portable aie condtioner
Remove the rear cover and clean the unit throroughly. Use a can of air duster with the little hose to carefully clean the drain holes in the drip tray under the evaporator (upper radiator) let the unit fully defrost, drain the unit from the bottom plug. Clean the fins wth a toothbrush and windex if needed. Reassemble and run the unit in fan mode for an hour to let it dry out.
Jul 08, 2012 | Windchaser PAC9 Air Conditioner
Why does our LG air conditioning unit leaks? It's inside our room and the dripping water is damaging our wooden floor.. Please help.. thanks!
The drain is stopped up or the unit is not tilted back enough to drain out the back. If the drain is stopped up sometimes you can blow it out with compressed air from the bottom of the front coil. If the unit is not tilted enough in the wall or window it cannot drain out of the proper drain hole in the back of the unit. Hope this helps you.
Apr 12, 2011 | LG Heating & Cooling
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
No cold air....external fan blowing....line between furnace and compressor unit is cold (with ice on it)and dripping water
Check your air filters and replace if necessary. Check the indoor and outdoor coils and clean if needed. If the line is still is freezing get the refrigerant charge checked.
May 03, 2010 | Honeywell ER150B Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
Water dripping from air condtioner-inside room
your evaporator might be dirty needs service or the drain pipe is clogged
Aug 01, 2009 | Heating & Cooling
Air conditioner
Possible solution for susuns: turns out my problem was an improper freon charge. If your problem is the same as mine your a/c cools very well, but stops blowing air after about 20 minutes. If so, your evaporator core is freezing over and the ice is blocking air flow. Also after parking the truck water will continue to drip from the truck for a long time. To test this theory next time it occurs, switch the selector to vent and the fan to high. You should notice the air flow return within 5-10 minutes or less, however the air will still be quite cold due to the ice formed on the core. If all this fits your situation, take your truck to an experienced technician and have the freon pressures checked. My system needed to be charged a little on the high side to prevent the freezing up.
Hope this helps, capn0623
Aug 07, 2008 | 2003 Chevrolet S-10
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
