Question about Canon imageRUNNER 400S Copier
Can't access system settings on Canon imagerunner 400s
I press "additional functions" on control panel but can not access "system settings". It does not appear on the control panel.
I have canon gp 225 copier ,
had a problem with a error message & now i cannot read anything because the disply is gone . What shall I do ?
Posted on Aug 29, 2009
Hi
canon image 400s can't print to computer lpt port
    Sniper:
  • 103 Answers
Turn off the main power switch, and
disconnect the power cord.
Remove the copyboard glass; then,
remove the screw, and detach the small
cover from the IP cover.
remove the remove all eprom dccon ram
& insert again & start the machine.
Posted on Aug 28, 2009
How to reset E005 error on Canon copy machine? Checked cleaning web. is OK.
You will ahve to reset the copy count for the web to zero. Get in service mode by pressing the additional function key, then the 2 & 8 keys at the same time and then the additional function key again. This should get you into service mode. Press COPIER, COUNTER, MISC, FIX-WEB, then I believe OK. Turn off the copier for about 10 seconds then turn it back on. This resets the counter.
Oct 21, 2011 | Canon imageRUNNER 400S Copier
My cannon image runner 330 n says to turn switch on and off then says eoo5 on it what does it mean
this code means you should replace web roller. to start machine temporarily go in service mode. i.e. additional function 2&8 again additional function press copier press counter on top press misc press cleang. web or belt.press C from key pad. the value will become zero in bracket.press ok.switch off and on the machine .E005 will disappear but replace web roller soon.
Aug 09, 2011 | Canon imageRUNNER 400S Copier
CANNON IMAGERUNNER 400S ERROR CODE E0005
This is the code for the cleaning web in the fuser. This will have to be replaced ( P/N FY1-1046-000 ). The error code has to be reset my going into the service mode. Press additional functions, then 2 and 8 keys at the same time, then additional functions. Press copier, then COUNTER, then MISC, then FIX-WEB, Then the Clear key on the control panel. The counter should go to all "0's. I believe you have to turn off the main power key and power up but I'm not sure.
Jun 08, 2011 | Canon imageRUNNER 400S Copier
Error : Hard disk full How to free memory in hard drive of IMAGE RUNNER 400S machine
hai
power on the copier, press the 3rd function key of panel board (lick. PRINT or OPTION/IF)
panel display go to printer mode ........ WAIT....
then ......... GO TO SET -UP YES or NO press NO
then ........automatically re boot the system
then.........display PRINT PAGES
CONFICRATION press CONFICRATION
now.......conficration data senting to print that time display CANCEL JOB, RIP, INFO etc.,
press the CANCEL JOB then YES
now .. old data automatically ereased.
then copier OFF / ON
best of luck.
Feb 26, 2011 | Canon imageRUNNER 400S Copier
How to know IP adress for Canon ir c6800
On the control Panel
Press Additional Functions Key.
Press Report Settings
Print List should be 2 rows of choices/ Select Network and print list. TCP/IP will be on the print out.
To Change the IP Address
Press System Settings
Press Network Settings
Select TCP/IP Settings
Enter New Address or turn DHCP on
Back out by using reset key on control Panel.
Be sure to re-Power the copier by turning off/on at the main power switch on the right side of machine or any setting will not take.
Mar 22, 2010 | Canon imageRUNNER C6800 Copier
How to access the service mode for a IR400s
1. Starting Service Mode and Making Selections
1) Press the asterisk key ' ' on the control panel.
2) Press '2' and '8' on the keypad at the same time.
3) Press the asterisk key ' ' on the control panel.
• The display changes to the screen shown in Figure 14-801, indicating the connected
accessories (FEEDER, SORTER, FAX)
Feb 22, 2010 | Canon imageRUNNER 400S Copier
How do i find out the IP address to my Canon Color Imagerunner C33880i?
Description
Since the scope ID had been set under Additional Functions > System Settings > Network Settings > TCP/IP Settings . In the typical network setting
Field Remedy
1. In Additional Functions > System Settings > Network Settings > TCP/IP Settings and press [OK].
2. Turn the main power switch OFF and then ON to restart this machine.
4. Execute the Ping command 60 sec after power-on to check if the host responds it. PLS RATE ME !!!!!!!!THANK U
Sep 23, 2009 | Canon imageRUNNER 400S Copier
How could I set up a password for Canon IR 400S? I have access to Advanced Features but do not see whitch button to tap...
try this : press * with head press the custom setting browse it you will find to activate dept code then you need to have dept code id then password for ex.dept code id -0001 password 9999 you need to enter this two info to open the copy functions hope this will help
Jul 11, 2009 | Canon imageRUNNER 4570 Copier
E677
press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Oct 02, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
320 people viewed this question
old marine
old marine
