Question about Whirlpool Refrigerators
Need to level the refrigerator. It is a side by side unit by Whirlpool ED25TQXFW02 Serial:SH4940056 FG1298
Used shims to level. Could not find feet to adjust.
Thank you all for your help.
cmbowser
Posted on Aug 03, 2009
  • Whirlpool Master
  • 4,654 Answers
Before leveling, unplug the appliance to avoid an electrical shock hazard. Never tip a refrigerator or freezer, it is very heavy and can fall causing damage or injury. It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers. If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An icemaker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then retightening the screws.
Thanks, Sea Breeze
Posted on Jul 29, 2009
Whirlpool ED5Lhextd00 side by side ice in bottom of freezer. Cleaned back, ran hot water through, turned off for several hours, leveled off still water builds up and freezes in the bottom
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Refrigerator.
Mar 01, 2017 | Whirlpool Refrigerators
Refrigerator wiring diagrams
Hi Mr. Ashton. We understand you need a wiring diagram for your unit. We do not have those online, be we can email them to you. Please call Whirlpool at 866-698-2538 with your full model, serial number, and email address handy, so we can email you the diagram. I hope this information is helpful. Sincerely, Melaine, Whirlpool Socail Media.
Jun 22, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a Whirlpool side -by- side 25 cu.ft. want to know about what age it is?
Hi.
It depends on the model number. Whirlpool started building 25 cu.ft over ten years ago and the model is still being produced. Please find the serial and number printed on the refrigerator service tag and give us the complete model number along with serial number. The model number will tell us the initial date of production, the serial number tells us the date of production of the specific unit. Here whirlpool date codes explained. To find the service tag check in locations illustrated below.
Aug 19, 2011 | Refrigerators
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My son just bought a new Whirlpool refrig last week from Lowes and can't find the serial number. Where would it be?
Hello, Thank You for using FixYa. I will be helping you today.On the right side wall at the top of the fresh food section.So in the fridge right side look up. If there is no model or serial tag whirlpool will not honor the factory warranty. If its not there return the unit to the store.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Level refrigerator
Remove front kick panel (Should have a screw on each side) and once removed you should see 2 bolt heads 1/2inch approx, they will require winding out to lower screw in to raise...
Jul 18, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Doors are hard to open on my new Whirlpool Conquest sided-by-side
2 things come to mind:
1) Check to see if the unit is level
or
2) if it is simply a suction issue when opening, try wiping the big gasket and the contact surface with some furniture polish
Aug 10, 2009 | Whirlpool GS6NBEXR Side by Side...
My whirlpool gold side by side serial # slo539783 model #gd
Sound like you have a refrigerant leak I suggest to take it to a pro because you need lots of tools and knowledge to properly fix it And don?t let people tell you than is just to add refrigerant because that is a common myth or miss conception, refrigerant don?t ware out or burn out if the system need refrigerant is because there is a leak some where.
Jun 07, 2009 | Whirlpool Refrigerators
How can I level my refrigerator, my floor is not level.
place quarters under the un leveled side. that should do the job. Plus there should be adjustment screw outs on the bottom of the unit.
Jan 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
389 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
