Question about Dryers
Not hot air in dryer kenmore gas dryer model 78702895
    Scholar:
  • 84 Answers
Does this dryer have a back panel you can take off....if so, take off back panel and check the thermal fuse. Its small white skinny oval shaped fuse. If its not the model that has the removable back panel youll have to get into it. If it has a bottom panel take it off and look around for the fuses. The oe you want to check is the small white skinny oval shaped one....if you want you can check the other limits as well to ake sure...hopefully this helps.
Posted on Jul 30, 2009
  • Frank Jul 30, 2009
    does this dryer have a back panel you can take off....if so, take off back panel and check the thermal fuse. Its small white skinny oval shaped fuse. If its not the model that has the removable back panel youll have to get into it. If it has a bottom panel take it off and look around for the fuses. The oe you want to check is the small white skinny oval shaped one....if you want you can check the other limits as well to ake sure...hopefully this helps.
The air drying the clothes is cold, not hot. We have a Kenmore Elite Electric Dryer, Model 110 63952100
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
I have a Kenmore series 90 gas dryer that has been converted to propane, model 110.74912200. the burner will light and stay hot for about 3 minutes and then will cycle off and only blow cool air. I have...
I would suspect faulty gas valve solenoids. These electrical coils are right above the gas valves and when energized, these solenoids open the valves to permit gas flow. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. They will most likely come as a set from the parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 24, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 sereis not drying
before you call a technicia. check your thermal fuse which is located onn the back oif the dryer you will need to remove the back cover and it looks like this...it has 2 terminals.. on it...you can check itr with continuity..or unplugg your dryer...hook up the terminals...point is for em tyo make contactt do not hold it with your hand..and check to see if your igniter comes on.efdd9af.jpg
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore Model 110.747424000
check your exaust blower wheel...its defective
Dec 12, 2008 | Kenmore 72802 Gas Dryer
Kenmore model #78702895 78702 front load natgas dryer : ignites and heats at beginning of cycle, then cools cycle continues without heat
replaced both the black coils on gas burner they will sometimes go bad after first heat cycle
Dec 05, 2008 | Dryers
Kenmore gas dryer does not get hot
hi. thanks for the question .check the thermal fuse, at the back inside the dryer. remove back panel .thermal fuse is on the air duct , a small piece of plastic with 2 blue wires to it. replace the fuse also clean all venting .thanks the appliance doc
Oct 05, 2008 | Kenmore Dryers
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Dryers Logo
91 people viewed this question
Top Dryers Experts
