Question about Kenmore Washing Machines
Kenmore washer wont work on spin cycle
My washer will not work on spin cycle but all other cycles work, which part is most likely bad? It is a
Model number 20432990
ANd the main switch part number is 3951166b
  • bjingles Jul 29, 2009
    Ok I been ohming out the outputs on that timer and it appears it is closing contacts like it is suppose to, but it is too late to doing anything more tonight, tomorrow I am going to do as you said, and make sure nothing just keeping it from spinning, should I jumper some wires as well and just see if I can get cage to spin with wires direct hook up? It looks like a gear box?
  • bjingles Jul 30, 2009
    Well I wanted to give you an update since you helped me out. I checked out everything you said and it ended up being the DOOR Switch... I should of checked that sooner and will next time. I was able to repair switch. Thanks for your help.
  • 1,959 Answers
In almost every case, when a washing machine quits in mid-cycle, it's the timer. The lone exception would be if you have a failing pump. Before buying a timer switch, you should pull the bottom panel and inspect the drain hose and pump. Sometimes something will fall out of a pocket and wind up lodged in the pump, which would prevent the machine from spinning out and draining.
On the surface, it still sounds like a timer but it's well worth your while to check the pump just the same. Best of luck and feel free to post back with any questions.
Posted on Jul 29, 2009
  • Greg Margossian
    Greg Margossian Jul 29, 2009
    You could try but I'd be surprised if the issue is the tub itself or the motor. Although you're getting good contact on the timer, it's common for them to fail for a variety of reasons: broken gear tooth, stripped spindle etc. Let me know how you make out.
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Wahser wont run spin cycle.
Door switch is probably bad or connection is loose. Remove the top cover to gain access to the switch.
David Le
Apr 21, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Open Questions:
Washing Machines Logo
37 people viewed this question
Sal De
 Brian Main
Brian Main
