Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My mitsuishi tv power light is blinking rapidly and won't power
There was a power outage and now the tv has a rapidly blinking reen light and will not power on or off. Please help
I had the same problem with the blinking green light every time the electricity cut out. I finally figured out I could unplug the television for several minutes and it would reset the television. Then plug it back in and see if it works. If the green light still keeps blinking, then unplug the television for several hours and try it again. Good luck!
Posted on Jul 29, 2009
    Problem Solver:
  • 10 Answers
Check the fuse inside the tv
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
How do i fix my mitsubishj wd-60737 tv?
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section. Since due to the power outage there can be a possible short or leak in the circuit as the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multi-meter to check the continuity or shorting in components, if so detach from circuit and test. If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly, the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Mar 12, 2012 | Mitsubishi WD-60737 TV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
98 nissan altima front left blinker does not work when headlights are on, works when headlights are off but blinks rapidly ,left rear blinker works when headlights are on or off but blinks rapidly also
the rapid blink is because there is a bulb outage some where, Pull Over turn on left Blinker Get out of your car look at the front left blinker hen walk to the rear of your car and look at the left rear Blinker light then do the same for the right side blinkers if all are working rapidly your left right switch is bad
Jul 09, 2009 | Nissan Altima Cars & Trucks
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
487 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
