TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. If this doesn't do it, please reply to this post and we'll go on from there.
Put the disc in the drive and hold down the power button until it turns off. Then press it once again. It *should* boot off the disc. If it doesn't, you need to go into the BIOS and change the boot order.
Post back here with the operating system and I'm sure we can be of more help. Good luck!
Easy, take three fingers and double tap your screen. Now that your phone is back to normal, change your settings so that this doesn't happen again. Go to settings, click on general, click on Accessibility, click on Zoom, then turn it off. Now, this wont ever happen again.
Take the battery out for about 60 seconds then place it back and turn the phone on. If that doesn't work, you can try a master reset. This will erase all data on the phone and restore it to factory condition. To perform master reset, make a call and dial *2767*3855#. Hope this helps.
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
With your console powered off insert the Action Replay DS
Hold down buttons A+B
Turn your console on
With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
