Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Carb rods cannot get rehooked back up. tecumseh 8hp
Replaced the carb ( with new one )but now not sure how to hook the rods back up. cannot get the trottle to work right. would like to see picture of rod and springs to see what i did wrong
engine type tvxl 195-150226 serial # 91430
  • 81 Answers
SOURCE: tecumseh HM80 engine, new carb, won't run
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Posted on Jun 17, 2009
  • 582 Answers
SOURCE: i have a craftsman lawn mower with a tecumseh
LOOK CLOSE ON THE CARB THERE SHOULD BE A NAME OR SOME LETTERS OF WHO MAKES THE CARB GO ONLINE TO TECUMSEH AND YOU CAN GET A CARB BREAKDOWN DON'T GO TO SEARS TO MUCH RUN AROUND
Posted on Aug 22, 2009
  • 153 Answers
SOURCE: gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Posted on Sep 27, 2009
  • 110 Answers
SOURCE: 8hp Tecumseh engine how to adjust carb. when I put
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Posted on Oct 01, 2009
rycgl
  • 1545 Answers
SOURCE: problems with the govener. i got it used,thanks..
Here is a parts breakdown for your exact model with all parts for the governor and throttle listed. Use the zoom feature and you should be able to determine which parts are required.
http://www.partstree.com/parts/?lc=tecumseh&mn=LH195SP-67517D&dn=EHSSK501HSSK5X67517D-EN
Posted on Nov 28, 2010
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
Can you replace the whole spark plug wire on the coil on 8hp Tecumseh without changing the coil
Not unless you cut the wire and splice a new piece on, which I would not recommend. A new coil should cost you less than $20 and is not hard to replace. See the attached YouTube video on how to do it. https://www.youtube.com/watch?v=v6bQrNr4lv0
Feb 26, 2015 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh 8hp snowblower engine kicks back hard enough to break plastic handle. I checked the key in flywheel ,I cleaned the carb,checked the flywheel, andcleaned magnets and coil pick up. I tried to start...
surging when running is most likely normal ,they have a governer that control's the carb & rpm so it wont over rev. It has a paddle near the fly wheel to pick up wind from it when running hooked to the carb with a small lever and held stable by a spring. Check to see if the spring is too tight or sloppy. 8 hp is a pretty big motor and a kick back is not really un expected. But a plastic handle is kinda cheesy, a rubber or a wooden handle would be better.Good thing you have electric start!
Oct 08, 2013 | Garden
8hp Tecumseh engine how to adjust carb. when I put throttle on high it sputters drop the throttle back down its okay?
Oct 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a vm80 8hp tecumseh engine 150092D day
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
Sep 25, 2009 | Garden
Tecumseh 8hp HIGH REVING! snowblower
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Jan 10, 2009 | Mtd Garden
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
350 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
