Motor cranks over fine, has spark, has fuel(opened bowl drain & fuel came out). ran & started fine past 6 months, sat for one month, no start
SOURCE: honda 6500is wont start ran
Hi. If the saw ran fine six months ago I would first check the fuel oil mix. Make sure that you have the proper ratio of oil to fuel. Also check the spark plug make sure that it is not fowled or damaged. Then check for spark at the plug. Bcause of the amount of dirt and dust that chainsaws are subject to a clogged fuel line is a common occurance. Also check the air filter it may need to be replaced. If all of these things check out ok you may need to take it in for repair.
SOURCE: 1995 polaris 425 magnum lights and ignition do not work
If you have cranked the atv without a battery connected it will blow your light bulbs. Replace the bulbs not burning, leave a battery connected even if its dead and pull start if you need to. A battery must be connected. I read and found out myself the hard way, hope it helps.
