SOURCE: I accidently bought jet dry
jet dry cleaner??? im thinknin its also a dishwasher detergent???if so i wouldn 't worry about at all, no way to empty the dispensor, it will dispence on its own over the coarse of a month. but yea so long as its a dishwasher detergent i would not worry about harm to family
SOURCE: The dishes come out dirtier after they're "washed"!
Take out the botton dish rack and check the drain. Most likely there is a screen that is supposed to catch big debris and keep it from entering the drain. It's probably got a lot of gunck in it. Take the screen out and clean it and check under the screen too!
SOURCE: jet dry dispenser doesn't work, gets spots on
If you are going to do the job, order part from searspartsdirect.com . they will give you the image, part # and the price. the door panel comes off and and the dispenser snaps in with tabs that you have to pry up and push either out or in. unplug dispenser and make sure you lubricate dispenser gasket. then reinstall by pushing in and listen for the snaps as you push in. re connect the plug put on panel and re screw panel if you want a service guy to replace tell him you only want a dispenser changed and how much willyou charge,if you ask 10 tech you will get prices .choose the most experienced and cheapest.
