Question about Samsung Instinct Cell Phone
Phone getting hot /screen gets magnified/pulse ring- callinn out
Why would my new cell phone after just 10 min heat up real hot and had an issue with screen blown up (Magnified), and had made a pulse ring sound while calling people?
My LG235C flip phone seems to get hot after 10min of use. I replaced the battery but the same thing happens
A phone overheating even after battery replacement is not a good sign. I did not find any instances of other users complaining about such an issue with the model you mentioned. This suggests that the issue is with the phone you currently have. I suggest that you have an authorised service centre look into this issue
Apr 03, 2014 | LG Cell Phones
I tryed ringing from my doogee phone the call dosent last a minunte and heats up with in seconds
follow the steps below:
1-turn off and wait 10 min
2-wrap with 2 layers of foil
3-place in microwave (make sure that the microwave is very clean)
4-choose the rice and pizza temperature and keep it for 6:05 minutes
5-let it sit in the microwave with the open door
6-unwrap it when cold
7-wait 10 minutes
8-turn on phone.
Feb 18, 2014 | LG KC910 Renoir Cell Phone
Screen got hot and in a few min the phone went
sounds to me that the connection to your screen is messed up.
So - get another one, or fix your phone -
Hope this helps
thanks
Mar 31, 2010 | Motorola Mobility RAZR V3
Hi , my problem is a bit hilarious but its frustrating for me ,MY dog pee'd on my phone while i was sitting on my bed charging ..now the display keeps randomly working for 10 mins and then goes off i can...
take the battary out and let it dry - if you keep turning your phone on, than water might get on the circuit board and your phone will be dead for real.
even if your phone is completly dead - just leave it off and dry it ( with a bowl of dried Rice) NOT with a HOT Hiar Dryer - if you do want to dry it with a hiar dryer ( keep it Cool)
thanks - and I hope this helps -
Mar 30, 2010 | LG KC910 Renoir Cell Phone
Ok my v3 turs on but no screen comes up the phone rings incoming
I THINK THE RIBBON OF YOUR PHONE ARE DAMAGED..REPLACED IS NEEDED...
Mar 26, 2010 | Motorola Mobility RAZR V3m Cellular Phone
My cell phone is getting very hot when i have it on or when i charged it and the battery goes down real fast, just got a new battery yesterday
Its just friction: You see, When an electrical current flows from the battery to the phone, it creates heat due to resistance in the wiring and circuitry. The amount of heat generated when the phone is not in use is negligable. However, when you are using the phone you are consuming more power and, thus creating more heat. Nothing to worry about unless you notice the battery bulging.
Aug 05, 2009 | Motorola Mobility KRZR K1m Cellular Phone
What is the option for cell phone activation of the system
Sorry. There is no option for cell phones. The unit requires what little voltage that comes over the red & green wires to use it. (It's the voltage that makes your normal phone ring before you pick it up, otherwise there is no voltage in a phone line). So without a regular phone line, it's not going to do what you want.
Jan 31, 2009 | GE Security Simon 3 Wireless Home Security...
I droped my phone in the water and it turns on but the screen won't work. what do I do
well, what you need to do is take out the battery first of all. Second of all, you should try baking the phone in the oven on the lowest setting it has, for like 10 or 20 min and let it dry out. It may work after that. If not, have your phone provider back up your phone numbers, and then get a new phone. AND, if you dont really care, you COULD soak the phone in distilled water to cleanse it of any impurities and then heat it again to dry it out.
Aug 08, 2008 | Sony Cell Phones
Battery gets hot and won't hold a charge; plus shattered LCD screen
the glass and LCD can be fix and replaced but the main-board heating up is saying that the board needs to be replaced but you should just purchase new one.
Jun 26, 2008 | Motorola Mobility RAZR V3
Samsung Instinct Cell Phone Logo
165 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
