-   Ditto. A popsicle stick was retrieved from the food grinder -- the end of it was sticking up under the lower spray arm. We removed the stick and the machine is now much quieter, but it is v-e-r-y loud. I want to take off the lower spray arm to see if another stick is lower in the grinder but the arm will not come off. The top plastic knob above the lower spray arm does not move.-   popsiclestk
I suggest you take a look at the technician repair sheet that should be stored inside the front panel at the bottom of the door. Remove that panel under the door with screw driver. Inside, attached to the panel, you should find a troubleshooting guide and solution for technician. But it is easy to follow.
It'l tell you how to remove things.
The pots and pans light flashes and the dishwasher won't start. The cancel button has no affect. The...
(More)
The pots and pans light flashes and the dishwasher won't start. The cancel button has no affect. The digital display shows --. I unplugged the unit and after plugging it back in, there was a 2 in the display and after a short while it went back to the -- and the pots and pans light started flashing again. Any ideas wiuld be appreciated. Thanks
my dishwasher will not come on at all. The power is good, but nothing happens when I close the...
(More)
my dishwasher will not come on at all. The power is good, but nothing happens when I close the door... and there is standing water in the bottom of the machine. It stopped in the middle of a wash.
