Question about Vizio L37 Television
Yellow light is so I have power but remote or
Yellow light is on. I have power but remote or power button will not turn on TV and no green light
  • epeirce May 11, 2010
    Me Too! Same problem tonight. The TV was on and turned itself off randomly. Now I have a yellow light but can't get it to turn on or the green light..... uh oh.
  • afterhourstv May 11, 2010
    What kind of TV do you have?
Its a vizio l37. I bought it in 2004 from Sams and haven't had any problems until now. We took it to a repair shop and they charged me $55 to tell me it was dead. They said they could fix it by replacing the main board which costs $250 with an additional $250 in labor. We said no thanks to the $500 repair and bought a new tv for $600. Now its in the garage and I'm wondering if there is something I can do to fix it for less. Seems like a waste.
Posted on Sep 02, 2009
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
Then enter 9911, the green light on remote should flash twice.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Yellow power light will not turn green
It sounds like U have a bad box. This seems to be the most common problem with them, besides not picking up all the channels.
May 01, 2009 | Televison & Video
The power button turns green when turned on on my WII console. However, no image is seen on t.v. What can be the problem?
The power button turns from yellow to green. This is correct.
Verify the cable is plugged into the back of the Wii and the Red, White and Yellow connections are plugged into the corresponding places on the TV'
With your TV remote go through the "Inputs" on the TV to verify operation. If you still don't see anything, you should try it on another TV before returning the Wii for repair.
Good luck with this.
Mar 21, 2009 | Nintendo Wii Console
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Vizio L37 Television Logo
197 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
