Question about Maytag 24 in. MDB3700 Built-in Dishwasher
DWU8260aax dishwasher, Maytag
There is a fine, white, dust on all the bottom rack plates after running any length wash, and all air dry/ heat sensor combinations have no affect. There's just a fine, white, baby-powder like dust that seems to appear like magic after the dishes where just rinsed, but allways end up dry and coated with this powder
  • Crazyfingers Nov 23, 2007
    Cascade, about half way up (1 - 2 oz) in the regular soap side, I've never filled the extra side. Same amount and brand I've been useing for ever. All the spray bars are clean and functional (I actually put my writeless camera inside the washer for a cycle to see what might have shown to fail but nothing) and since this started I've cleaned the filter and ran CLR for a cycle as well. The dust is taunting me now. I look before the dry cycle and everythings good and soaked. After dry the taunt fairy dusts all my dishes. I'll get some pics but if anyone else has any info that may help, please speak as the dishes are piling up fast and I've got a flu now so manual washing seems as easy as flying.
  • 447 Answers
What kind of soap do you use??? How much??
Posted on Nov 23, 2007
Dryer not drying
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 16, 2015 | Washing Machines
Whirlpool dryer, when set for auto dry low heat, or timed heat, then dryer runs fine, when set on auto dry high heat timer doesn't move, what could be the problem? does it have to be the timer?
Feb 10, 2015 | Whirlpool Dryers
My Maytag bravo Dryer is not drying my clothes correctly. The timer on the dryer keeps going up higher indicting it needs more time to dry?
Oct 13, 2014 | Dryers
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
Clean light flashing and will not run
This is Common With Kenmore Dishwashers. You never mention the Make and Model, but let me provide you with a Solution, i offered to all the People who have this Problem :-
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model. So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec or Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 10, 2010 | Dishwashers
Dishwasher will not run clean light keeps blinking
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
or
Hope i helped you.
Jan 10, 2010 | Whirlpool Dishwashers
Clean light flashing, won't allow cycle to run.
Ifthe clean light is the one flashing then your dishawasher could have aheater circuit problem (depending on the age) or this could simply justbe water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice andtry the dishwasher again making sure to run the water at the kitchensink till it is hot before starting the dishwasher, if this trips andlocks you have a problem with the heating element, or temp sensor.
Pressthe heated dry button followed by the normal cycle button, and thenrepeat once. You should see all of the lights come on for a second ortwo, and then the dishwasher will work again.
If you haven'talready, take a look under the kick plate in front to see if there is aschematic tucked in there somewhere. Whirlpool has put theirdiagnostics for specific models on these.
or
Hope i helped you.
Read the Testimonial by the one of the Customer's who had the same issue :-
http://www.fixya.com/support/t3124974-clean_light_flashes_7_times_time
Dec 30, 2009 | Kenmore 24 in. 16934 Built-in Dishwasher
Clean light flashes, washer won't run
or
Hope i helped you.
Oct 07, 2009 | Whirlpool Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
522 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
