My kenmore 800 washer stops mid fill. i push in
My kenmore 800 washer stops mid fill. i push in and pull out knob and it finishes cycle well.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sounds like the timer has a bad spot in it probaby a factory thin spot in the dial
it's where the coil or filiment has a gap even a micro gap or wear spot can cause this
Posted on Jul 29, 2009
Kenmore 800 series washer not draining; stops at that cycle; have to manually turn dial to spin/drain cycle to get it to finish; Need to trouble shoot n fix. Help?
After you advance the knob, you are saying that it will finish the rest of the cycle? If that is the case, more than likely, you will need a new timer for your washer. Hope this helps!
Aug 19, 2015 | Kenmore Washing Machines
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Washer wont complete cycle. its full of water and I cant drain it
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
Nov 30, 2008 | Kenmore 24902 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Washing machine won't drain
It sounds like you may have some bad contacts in the timer or you may have a bad lid switch which will not allow it to go into a spin during the rinse cycles or the final spin.
Oct 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
313 people viewed this question
Top Washing Machines Experts
