Question about Casio Exilim EX-S880 Digital Camera
My camera wont charge correctly
My charger has never had problems prior to this, but now its going psycho. Alright, so I plugged my camera into it and the red light was solid for the first minute or so and then it started to flash, I left it over night and it was still flashing red in the morning. I took out the battery and put it back in, unplugged the charger and plugged it back in. Then I put the camera back on the charger pushed the power button on my camera, and once again it was a solid red light for about 20 seconds and then it started to flash again. WTF?!
  • 7 Answers
I had the exact same problem so I went searching for an answer. Here's what I found and it really did work. I had to do it about 7 times... and I read others had to do it about 20 times. But worked for them as well. Good luck!!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
Testimonial: "THANKYOU =)"
When i plug my P530 in the green light comes on for 1 second and then its off. so it wont charge and camera wont turn on
Not knowing how much you use the camera makes this a harder question to answer. Make sure the battery is fitted correctly but it might be a worn out battery. Using it a lot will eventually wear the battery out and only using it occasionally can affect the battery as it isn't charged.
Are you charging the battery while it is still in the camera? A separate charger is more effective. It might be worth investing in a charger if you don't have one and/or another battery.
Duracell supply both at sensible prices. Nikon CoolPix P530 Battery Charger
Jan 16, 2018 | Green Cameras
Camer will not power on
If your battery does not seem to charge, then you need to carry out some tests on the device, the battery and the charger. First you insert the battery into another cam corder then you try to charge, if it charges, then it means the battery is okay and if it does not charge, then it means the battery is bad and need to be replaced.
Then i will advice you take the charger and try to charge another device to see if it will work, if it works, then it means the charger is alright but if it does not then it means the charger is bad and need to be replaced.
Finally, test the camcorder by plugging a well tested charger and battery into it and trying to charge it, if it does not charge then the problem is from the camcorder.
Feb 12, 2014 | Canon MVX20I Mini DV Digital Camcorder
Battery wont charge
As in the first part of the manual is explained, when you have inserted the battery correct and you then plug in the charger, the charger light should go on. When the light is out, the battery is charged. When the light blinks, your battery is fault.
When the light does not go on, when you plug it in a power outlet, the battery is not inserted correct, or the contacts are dirty.
If you want to clean the contacts, please only use a dry cloth. Never us a sharp tool. It would damage the contacts bend repair.
Even when you plug in the charger, with a fully loaded battery, the light should go on for only a few moments.
Make sure the power outlet works normally. and the power cable is not defect.
Dec 29, 2013 | Fuji FinePix F460 Digital Camera
Battery wont charge on my Mid m9100 android tablet pc
Are you sure the charger is working correctly? When you plug the charger into the tablet and into the wall, then leave it alone for half an hour, does the charger feel at all warm? Is there power to that outlet, or is it a switched outlet (like one used for a lamp)?
If the charger feels warm after half an hour, does the back of the tablet also feel warm? It may actually be charging.
If the charger is dead cold (same temperature as a table) and you're sure that it's plugged into a good outlet and correctly plugged into the tablet, then it's a good bet that the charger is dead & you need to find another.
Can you also charge that tablet with a USB cable connected to a PC? That'd be a good test. Try doing that - if that ALSO will not charge the tablet, then there may be a problem with the tablet itself.
Mar 02, 2013 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Alright so i wanted to know if i can charge my Casio Exilim Zoom EX-Z700 Digital Camera without the actual charger but just plug it into my computer and it'll charger that way. i've tried this...
No. You need to plug the camera into the cradle and plug the cradle into a wall outlet. Connecting the camera to the computer merely drains the battery faster, as the camera has to spend juice communicating (or trying to communicate) with the computer, even if only to say it has nothing to say.
Aug 23, 2011 | Casio Exilim Zoom EX-Z700 Digital Camera
My camera wont turn on. There is a problem with the dv port. Would this keep it from charging? Because it wont charge and I think its because the dv port is messed up.
Your probably correct on this. I have a similar issue with my Sony and the camera dock. my charger works but I can't download the video from the camera because of the dock. Is there a DC in plug on the camera? mine has a small plug that is coverd in rubber on the back side and on the bottom. Look and see if you have this plug, you can just plug the wire going to the dock into the camera and charge it that way.
Mar 28, 2011 | Canon ZR100 Mini DV Digital Camcorder
Battery will not charge
Jan 12, 2011 | Sharp Video Cameras
Mustek GSmart S50 Digital Camera wont turn on. Cant seem to charge the Li-ion battery. LCD Display wont turn on. Looking for suggestions to fix it, e.g. does a service manual (possibly downloadable)...
try first this ..for to see if the adapter/charger is to blame ..or the camera has a issue or it is the charger plug ...
This camera has the possibility to be charged from a computer in the usb mode...so ..connect the camera to the computer with the data cable ...than after you closed all the autoplay and whatever might start on computer ..click on the icon in the tray system ..and select remove ...but leave the camera in ...and on ...and look if it charging...anyway in the usb mode it is charging and may be a way to use it ..and if it does..it means that the charger is burned or the plug do not makes contact well..and either clean or change the plug ..after you measure the charger and see its working ...This way you eliminate them on eby one ...if it charges with the usb cable and powers on ..measn it is ok ..but a issue is with the charger ..and if this seasm to be ok when measured or tried with aanoter device ..than the only thing that remains is teh charger plug ..and you will have to change it ..
But , if with the usb cable r ..leaved on ....and off at the time about an hour or two ...and still not powers on ..it is probably another thing much worse ..the board or ..the battery ..and you have to analyze if it 's worth repairing ..
Jun 03, 2010 | Mustek GSmart S50 Digital Camera
Fuji Fine Pix Z5 battery won't charge
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
Mar 31, 2008 | Fuji FinePix Z5fd Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
295 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
