Question about GE Refrigerators
Ice dispenser will not dispense ice when selecting either crushed ice or whole ice. I replaced the motor but it still will not work.
  • henv Jul 29, 2009
    Thank you for your input. I have a GE Profile TFX25PR.
    This is a side by side frig/freezer. It appears that the door switch is working because I depress the switch and press the dispense button and the plunger that releases the dispense lever actuates.
    Henv
  • GE Master
  • 4,654 Answers
Your door switch may be the problem, it is a double pole single throw switch. When the door is closed the switch directs power to the dispenser. It also could be the control module in the dispenser panel. Not knowing your model number I must assume you also have a mother control board on the back of refrigerator. Send the model number found on the bottom of the fresh food section door frame and behind the door seal. Hope this helps, feel free to ask me more questions and please rate me! Thanks, Sea Breeze
Posted on Jul 29, 2009
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Mar 15, 2009 | GE Refrigerators
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Ice maker will only dispense crushed ice
You may have a broken solenoid inside the motor assembly.  The solenoid controls the arm for cubed or crushed ice.  The only way to tell is remove the ice dispenser motor assembly and look at the solenoid.  If the solenoid is broken, replace it and everything should be ok.
Aug 18, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice dispenser in door- won't deliver whole ice
Dear Sir,
I have purchased a whirlpool refrigerator on dt.05.11.2006 from M/S.Ganesh Enterprises, Angul bearing Invoice No. 335. last few days the main door of the refrigerator is not working properly. A part is broken from the door(clamp). Inspite of repeated contact and reminder the dealer have not taken any action till today and telling that the parts is not available.
I am very much dissatisfied with the service of the dealer. Therefore I am request you Sir, kindly look into the matter and necessary action in this regard please be taken.
Thanking You,
Yours faithfully,
R.Agarwalla,
06764-232367, 234667
Jul 15, 2008 | Refrigerators
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
