Home | Samsung | (SH-S162L/BEBN) DVD RW Burner | I'm out of ideas.
Samsung DVD RW Burner
Problem for Samsung (SH-S162L/BEBN) DVD RW Burner
I'm out of ideas.
By qwert78 on Jul 29, 2009
I've checked wiring, run BIOS, set it as a slave, run device manager, just about everything there is to do and I can not find out why my SH-222A won't read any discs; CDs or DVDs.
Clarification Request
Posted by Chris42 on Jul 29, 2009
Does it show up in the device manager?
Solution #1
posted on Jul 29, 2009
Somewhat Helpful)
teckman45
Rank: Master
Rating: 56%, 4 votes
Hi,I would go to the manufactures website, download and reinstall the drivers.
Was this helpful?
Yes
No
Solution #2
posted on Aug 06, 2009
Not Rated)
dbucyk
Rank: Wiz
Rating: 84%, 77 votes
If you updated the BIOS, what type of board is it. Depending on the type of BIOS, you may need to just change a setting in it. Some BIOSes allow you to select from IDE controllers and RAID controllers.
If the system is set to master and slave and you went through the controllers in the BIOS and it still doesn't recognize, then let me ask you. Does the drive at least get power.
What about trying a different ribbon cable. Is it set to Cable Select, is it 80 pin?
Was this helpful?
Yes
No
Solution #3
Not Rated)
juyruyrfiujh
Rank: Wiz  Computer Accessories  Expert
Rating: 81%, 666 votes
OK I'll try.
So wiring OK BIOS OK (it's recognised there)
Shows in device manager.
As you got into device manager you mut know how to get into the control panel so, put a disc in and go there. Open administrative tools/computer management and select disc management on the left and tell me if it is shown there. It should be shown (on the top right) at the bottom of the list under your HDD's with thef disc in it and layout/type/file system/status Maximising the screen will help as next you look at the lower half .Again it should be at the bottom under the HDD's and should show the size of the cd/dvd you put in.
Check all of the above and post back along with the OS you are using and we'll go from there.
Was this helpful?
Yes
No
Popular Solutions for Samsung DVD RW Burner
Questions and Unsolved Problems for Samsung DVD RW Burner
Do you recommend Samsung (SH-S162L/BEBN) DVD RW Burner?
Answer
Answer
i have a dvd writer of samsung but this can play only cd when i insert a dvd this show that this... (More)
Answer
as soon i connect sata cable it turns off and doesn`t work
Answer
I have a Samsung sh-222. When I play a CD audio the sound is fine and everything. When I play a DVD... (More)
Answer
dvd rom always is open trey ? sh-s202, i can`t close it ! I try reinstal firmware but it dosnot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung DVD RW Burner:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
