Question about Garden
Right wheel doesnt propel - Garden
    Novelist:
  • 133 Answers
Maybe the teeth on the inside of the wheel are stripped out. check and replace worn out parts
Posted on Jul 29, 2009
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Pontiac grand am 2002 propeller noise at the driver wheel when slightly turning steering wheel to right
That axle nut has to be put on with an impact gun or a large breaker bar since the torque for it is as much as a cyl head bolt.
It takes a special deep wall socket too.
Most applications have a flat washer behind the nut and something to lock it in place too.
Jul 06, 2012 | Pontiac Cars & Trucks
Pontiac grand am 2003 propeller noise at the driver wheel when slightly turning steering wheel to right
If you have replaced both front hub bearings, and the noise was happening before the repairs, that would leave the axle joints.
Jul 06, 2012 | 2002 Pontiac Grand Am
Self propel doesnt work
The cable or spring that engages the S.P. gear box has broken or the belt that drives the wheel has broken.
Good Luck!
Jim
Aug 16, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybilt xp, and the self propel fontion
Does the drive shaft going to the wheels turn at all?
If it doesnt you may have a unsecured pulley on the engine.
If the shaft does turn when you engage the tranny your next stop is taking the wheels off and checking the wheel clutches. Sometimes called sprag clutches. They are probably both stuck in the unlocked position. You need to clean them up by removing all the greasy material covering them and putting them back together with just a few drops of light oil.
I hope this helps. Good luck and be careful!
Jul 28, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My scotts spreader propeller will not spin, i have used it twice and clean and maintain it well, when i went to push my yard yesterday the propeller wouldnt move, how do i solve this
Had same problem. Empty contents into a bucket, tip it over and push wheels together. Apparently right and left wheel axles pull out of the gearbox that run the propeller. I think if you can see the flat part of the axle, it has pulled out. Push the wheels together and the axle flat part will engage the gear box and spin the propeller.
Jul 08, 2009 | Scotts Company Scotts& Accugreeen 3000...
Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
