Question about Belkin (F5D72304F5D7000) Router
My Belkin N Router isnt broadcasting a wireless signal.
It was working just fin and one day the wireless light went off and so did the signal; so how do I reach connectivity again?
  • Belkin Master
  • 4,338 Answers
Reset the Router:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds
Posted on Jul 29, 2009
Belkin N750 DB wireless connection drop
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 23, 2012 | Belkin N750 DB Wireless Dual Band N Router
My router will randomly stop broadcasting its signal and shows a green light that it is connected to internet but still wont broadcast i have to unplug it for about fifteen secounds for it to start...
You will need to update the Firmware in your computer to do that here is a direct link to show you how step by step Good Luck.
http://en-us-support.belkin.com/app/answers/detail/a_id/497/related/1/session/L2F2LzEvdGltZS8xMjk0OTI5NDU5L3NpZC8yUlBkZlpqaw%3D%3D Copy and paste into address bar.
Jan 13, 2011 | Belkin Basic Wireless Router
Low broadcast signal
Turn off or move any other gadgets that may emit a wireless signal. Other wireless signals may prevent the router signal from being as strong as it should be
Nov 27, 2009 | Belkin (F5D7633UK4A) Wireless Router
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Belkin wireless router disconnects from wildblue every 2 min
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the Belkin wireless router away from walls and if possible move the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. changes the default password, setup encryption use WAP2 or WAP, change the default SSID, turn off SSID broadcast, and for added protection, enable MAC address filtering which allows the MAC address/es of your wireless card/s to connect to your wireless router.
Sep 23, 2009 | Belkin (F5D5231-4) Router
Belkin router signal not showing up for Wii or Laptop.
If no signal, check router config. Use your
internet browser to look at router's settings.
By default the password on most Belkin routers is left blank, and the default IP address is 192.168.2.1 Check all you router's wireless settings in case disabled or incorrect. Make sure the laptop's wifi button has been toggled to OFF. Routers do die - esp the lowend ones. New wireless G router = $20 on sale.
Jul 07, 2009 | Belkin (F5D5231-4) Router
Belkin N Wireless Router - wireless light no longer lit up
Just in case it helps anyone else, I just had to toggle between broadcasting SSID and fixed the problem.
Jul 02, 2009 | Belkin Wireless-N Wireless Router with...
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
No wireless signal
Most home router has an IP address of 192.168.1.1 or 192.168.2.1. If you dad's laptop can connect to the router just fine, then it's a problem with your linux laptop. Can you see other wireless networks on your laptop?
Jul 23, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D72304F5D7000) Router Logo
502 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
