Question about HP Officejet 5610 All-In-One InkJet Printer
How do you print from dark to darker using HP officejet 5610 printer ? When I am photo copying, the result of a copy, is hard to be read.
  • HP Master
  • 4,338 Answers
There is a setting on the control panel for "Best Normal or fast"select best for high quality, Normal for normal and fast for draft copies.
Posted on Jul 29, 2009
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Mar 28, 2014 | HP Officejet 5610 All-In-One InkJet...
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
5610 printer wont print photos
Will it print photos once copied into a word document first?, if not let me know.
Dec 27, 2012 | HP Officejet 5610 All-In-One InkJet...
Print is to light. How do I get it to print darker
there is a option u can do it dark and light,,,
press dark or light botton, than its gives u dark print ,,
if there is ok than change your cartridge,
May 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Everything prints blank, but the ink is fairly new and there are no errors showing up on the screen of my HP 5610 all-in-one printer/ copier/ fax
Hi !
As you are using HP officejet 5610 printer, so perform the following steps on the printer to print a self test report to check the functionality of the printer.
Press Setup on the All-in-One then Press 2 then press 6.
If you are unable to perform the above steps, then try to make a copy using the scanner glass ( By placing a text document face down on the scanner glass and then press color copy button.).
If the printer make a copy or prints the self test page, then it confirms that the printer is working fine.
The issue could be with the software side. However, if the printer again prints the blank page, when you try to make a copy or printing a self test, then the issue is with the print cartridges.
Be sure that you are using the Hp genuine ink cartridges not refiled nor re-manufacture. Check the expiry date printed on both the print cartridges.
If all are correct, then perform the below steps to clean the print cartridges.
1. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridges , from the top to the bottom.
2. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
3. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Then perform the below steps to power cycle the All-in-One unit.
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
Then insert the print cartridges and try to make a copy and check for the result.
Please revert back to me if the issue occurs again.
With regards.
Mike
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Copying from HP 5610 All-in-One Printer
Can I do double sided printing like Company ID Cards on the 5610
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
386 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
