Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Chain brake puzzle
Don't use my Homelite Ranger 16" that much and am confused on how the chain brake works.
With the brake pull TOWARD the handle the engine runs fine but the blade will not rotate unless I squeeze toward me. When I let go it stops.
When I have the brake pushed AWAY from me the blade does not turn as well.
I have taken the chain and bar off numerous times and believe all is reinstalled properly.
To run the saw.... do I push the brake away, or pull toward me.? I feel silly asking this question, but my ego will survive.
Thanks
    President:
  • 583 Answers
The chain brakebar has to be pulled backtowards the operator,in the case of the cnainbar lifting and coming back towards theuser the brake bar will come in contact with the forearm on front handle and inturn that will click the bar oer and stop the chain thats the easy bit---- the hard bit is why is yours not working correctly i would like to see you blow the chainbrake handle and all associated areas with compressed air
Posted on Aug 07, 2009
  • 520 Answers
Some saws are different than others but you want the chain to be free when you pull the trigger. Most have to be pulled back towards the operator to release the brake. This is here to reduce the amount of injuries due to a kick back. It can be pretty bad if one of these saws hit you when the chain is spinning. But yeah if you pull it back that should release it. Hope this helps you out. If you feel that the solution has helped then please accept and rate. Thanks cj2176.
Posted on Jul 29, 2009
Looking for homelite model 3374 chainsaw
Pull the handle back to free position.
Jul 12, 2014 | Homelite Garden
Homelite Problems
make sure the holes on the bar are clean if they are fill with so-dust the oil will not pass inside of the bar
Oct 26, 2013 | Garden
Chain brake lock, how to release?
Pull the chainbrake lever back to the handle bar, regards Phil.
Sep 20, 2011 | Homelite ZR10926 16 Chain Saw
I have a gas powered chain saw and the chain wont turn on the bar, what can I do to fix the problem
Sounds like the chaibrake is on, pull the hand guard fully back to the top handle until the brake clicks off, now try again.
Jun 24, 2011 | Homelite ZR10926 16" Chain Saw
You don't get it people, no MATTER WHAT I DO, the chain keeps coming off the cheap electric chain saw. Both Homelite and Remington share the same problem. These DO NOT WORK! I haven't gotten more than 2...
Quit doing what you are doing before you cut yourself. The cut could kill or cost $10,000 just to live with an ugly scar. You chain is not staying adjusted correctly.
My Homelite does NOT do this. But my neighbors Poulan did. It thrashed the chain against the spike and threw it completely off. The adjustor didn't work right and an attempt to bolt it tight also failed. So I ordered the spike and the whole cover/brake handle/chain adjustor kit for it. Should get here from Sears in a week for under $40 USD.
URL: https://www.searspartsdirect.com/partsdirect/
Mod: PP4620AVX.
Parts items
(45) Spike 530014381 and
(70) Kit ezt c/br 545081874
Jan 15, 2011 | Homelite ZR10926 16 Chain Saw
I just started up my new 16" Homelite and the engine starts, but the mechanism that powers the chainsaw isn't rotating... any suggestions?
The engine needs to be accelerated to make the chain turn. The chain should not be so tight on the bar that you can't turn it by hand. Make sure the chain brake is off by pulling back on the brake paddle which has a 'toggle' effect--it should snap over to the new position. If still having problems, it is time to return for warranty exchange or repair. Hope this helps!
Jan 09, 2011 | Homelite ZR10926 16" Chain Saw
The motor turns on however the chain will not turn while engaged. How to get chain working again?
Make sure the chain-brake is off. Pull the chain brake handle back toward yourself until it clicks.
If that does not solve the problem it's likely theclutch sprocket is worn and needs replacing.
May 15, 2010 | Garden
Where can i buy a replacement chain for the expand-it prunner emmanuel1942@yahoo.com
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Mar 26, 2010 | Homelite Expand - It 10" Pruner Attachment
I have a Homelite Ranger 16'', the chain brake will not let the chain spin. Is that a clutch issue, or is there a adjustment on the handle of the chain brake
It's probably the chain brake not disengaging. If you are handy you can remove the clutch guard and spray some WD-40 around the chain brake (avoiding the clutch with the lubricant) and move the chain brake mechanism back and forth a couple times and see if it releases. If not, take it to a qualified mechanic.
Jul 22, 2009 | Garden
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
113 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
