Question about Vacuums
I have a Vax model U87-44_Be. I empty my hoover regularly and wash the filter. I am 80 years old and suddenly my machine is very hard to push. I would appreciate your advice. Margaret.
  • 1294 Answers
SOURCE: Westinghouse Top Load Washing Machine
Possible your outlet filter is blocked, it need periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first. Well, you have a record of sorts, 30 years!!
Posted on Jun 13, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine MOdel 22622100
If the sound is a grinding noise, this is usually a symptom of a gear case (transmission) going bad. However, it could also indicate a motor coupling that's starting to fail. If you look under the washer check for any drips or puddles of oil. If you find any, the transmission has begun leaking and needs to be replaced. If you find a black powdery looking substance, this is an indication of a motor coupling that is failing. I hope this may help you. Let me know what you find.
Posted on Jul 10, 2007
murdozzz2
  • 75 Answers
SOURCE: washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Posted on Dec 11, 2007
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
  • 5 Answers
SOURCE: vax 2400 perfomance pet overheating??
take it in to get looked at! it could be a elec. short which might cause an accident(ie. fire, shocking, explode....)
Posted on Feb 19, 2009
How do I clean the solid hepa filter on the hoover WI dtunnel2
I recommend blowing it out with a air compressor, some can be washed with water but water can make the fine dust pack into the pores. If it is over a year old it should be replaced as should the other filter or filters depending on your specific model.
Mar 13, 2018 | Hoover Vacuums
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
My new vax arrived damaged?
ok jot dwn all the details of the courier or carriers all involved in getting this vax to your doorstep .Ring the company you bought it from and tell them give them all the details including damaged model of your vax machine & Im sure they will replace it for you at their cost not yours
Aug 30, 2014 | Hoover Vacuums
Vax hoover suddenly hard to push on carpet
Make sure you have it set to carpet, other wise not sure
Mar 27, 2014 | Vax U89-P9-P Power 9 Pet Bagless Upright...
My Vax c90-vc-p-a cuts out after ten mins of hoovering. The filters are clear and we only purchased this a few months ago. Is there a simple way to fix this?
I have exactly the same problem with the same model, i purchased it mid August and stupidly did not register the guarantee within 28 days.......
Aug 26, 2011 | VAX Appliances 2000 Canister Vacuum
I have a Vax turbo force 2000w hoover and it doesnt pick up theres hardly any suction and then it cuts out. Any ideas what the problem could be?
Yep,
Your filters are clogged. As a result the motor is straining and overheating, then a thermal cutout operates.
Clean the filters in the top of the vax and if you are ussing a cloth bag empty and wash ot. If a paper bag, replace it.
All should be well
Jun 29, 2011 | Hoover Vacuums
Vax turboforce not picking up
Hello Guest, Please check that your brushbar is turning, if isn't then your belt has broken, once replaced your machine should be fine.
If you need further help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
May 11, 2010 | Vacuums
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
I got a vacumn from a friend who ungraded and though i used at her home when i got it home it would not turn on when plugged in and i check everything and no use. my friend lost her manual. im in my 60's...
Hi In the UK we have similar machines but they are made by Vax. If you can't source the correct user manual from Hoover.com consider the following - it is a free download.
http://www.vax.co.uk/downloads/pdf/vzl-60156016_v2_(brushbar).pdf
The Vax Mach 5 and Hoover model you have are the same other than the name. Dont forget to rate, thanks.
Feb 22, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Light on
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Mar 27, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
