Question about Jenn-Air 35 in. JGC9536 Gas Cooktop
Large burner igniter continually fires - Jenn-Air 35 in. JGC9536 Gas Cooktop
  • 5,603 Answers
Often there is a switch under the control knob that runs the igniter. I have heard that moisture from cleaning CAN cause this problem when it gets into the switch.
Posted on Jul 29, 2009
Igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Sparking ignition
switch Is stuck in on position
Apr 15, 2008 | Tecnik 27 in. TKH3515SS Gas Cooktop
Ignitors continue to ignite on other burners
the igniter switch are stuck /need clean contactor of the igniter .
Jan 08, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air 35 in. JGC9536 Gas Cooktop Logo
200 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
