Question about Radio Communications
How to convert Novi intercom from house wiring to phone line
I have a pair of Novi 980215 4-channel intercoms that don't work through my house wiring between buildings. I saw a video here http://www.youtube.com/watch?v=n3GMqvgQFjU that tells how to convert a similar intercom to send signals via phone line. But my circuit boards are different from the one in the demo so I wonder if you could tell me which wires to cut and splice into.
The AC wire attach to the board at ''W'' and Or''. A red and a black wire come off the board at ''R'' and Bk'' right next to the AC wires. The red and black go to the top of what looks like a transformer. Two yellow wires come out of the bottom of the transformer and connect to the board at ''Y1'' and ''Y2''.
I could post photos on my website if that would help. Do you think you can figure how to wire this for phone line?
  • 274 Answers
SOURCE: wiring cartridge
The "Standard wiring" is: Red = Right Hot= R Green= Right Ground= RG White= Lefty Hot= L Blue= Left Ground = LG Black if used is "Ground" and should be connected to a seperate ground circuit. Seems to me you are missing a couple of solder points. Also try twisting the pairs together but not all 4 together; i.e.(red & grn) (White & blue) to reduce "hum". Hope this helps.
Posted on Jul 16, 2007
catriver
  • 878 Answers
SOURCE: GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
Posted on May 30, 2008
driveallnigh
  • 89 Answers
SOURCE: Interference in our wireless intercom
Wireless routers operate on 2.4GHz frequency. It's very possible that your intercom is in the same frequency range causing inerference. Try and find the frequency your intercoms operate on. If you can't find it on the unit, search the internet for the name brand and maybe you will find the info. If this is that case, (as I suspect it is), the only alternative I can suggest is to change your intercoms. Be sure to check the frequency of the new intercoms before purchasing. Anything but 2.4GHZ should work fine.
Posted on Feb 26, 2009
  • 8 Answers
SOURCE: intercom feature not working
Is one of the 2 phones transformer plugged into a power strip? If so, try putting it directly into the wall, most power strips do not pass the signal properly
Posted on Jun 03, 2009
  • 49 Answers
SOURCE: Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Posted on Jan 16, 2010
Unpair devices
Hi. Once they are paired you don`t have to do it again. If you power up the two intercoms then press the A button it should link the two. Keith
Mar 01, 2014 | BUHEL Helmet Communication System D02...
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
Radio shack intercom 43-493
Do you by chance have a DSS cordless phone that is interfering? Normally these should work well up to over a hundred feet for sure. Try swapping channels on the intercom units and keep away from metal (Like a refrigerator) and motors.
Mar 06, 2018 | Radio Shack This easy-to-use intercom...
We have one incoming line that we don't want to ring. How do we program the Avaya System to stop ringing when a call comes in on that line?
At ext 10 or 11
press feature 00
LEFT intercom
LEFT intercom
Right intercom
enter extension number to change ringing on
the line buttons will light up if you touch the line it will change the flashing and the ring style.
Once done, press feature 00
Repeat for all phones.
Aug 03, 2011 | Avaya 700340193 Corded Phone
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    Intercom / page problem with AT&T phones model 944 and 955
    Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
    Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
    Feb 21, 2010 | AT&T 944 Four Line Intercom Phone
    CANT GET INTERCOM TO WORK
    Be sure you are pressing the correct extension key for the phone you are attempting to call. Just press 'intercom' and the key number (from the right side of the phone marked 1-16).
    Feb 18, 2009 | RCA 25414RE3 Corded Phone
    2-9450c telephone will not setup
    Each telephone must be connected to line 1 and line 2 for
    proper operation. The remaining lines 3 and 4 may — or may not —
    be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
    Sep 26, 2007 | GE 2-9450C Corded Phone
    Intercom
    I do not have any information on your specific phone but I'd like to try and help. Typically a multi-line phone set up like this would need a way to intercom between phones. I have not seen one that can utilize the same wires as the phone service but I also have not looked. It would also need each phone to have it's own identification (extension assignment). You only need two wires for each phone line but for intercom there most likely needs to be another pair of wires connecting all the phones together. I hope you have a manual. Look carefully at the section dealing with wiring up the phones to the phone lines. It should mention intercom at some point and what is required. Also, you can have up to 16 phones. Each phone must have a setting to choose a number between 1-16 or maybe 10-25, 100-115. By default these will all be at the same setting and you would not be able to intercom.
    Jul 23, 2007 | RCA 25414RE3 Corded Phone
    Radio Communications Logo
    124 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
