Question about Polaroid FLM-3232 Television
DirecTV Remote Control of Polaroid TLA-01511C
Have a new Polaroid flat screen with a DirecTV cable box. There are 150 TV selections for programming, but no Polaroid. Anyone know if Polaroid OEM's this TV from another company. Not an option to go thru 150 options.
  • 2 more comments
  • cavizoso Nov 05, 2008
    TLA-01511C polaroid lcd cant program with the direct tv remote control. I tried codes posted on several forums still no success.
  • chgokid1019 Nov 10, 2008
    need the 5 digit code for polaroid 32"in hdtv for directv remote
  • Anonymous Mar 17, 2014
    when I turn on my polaoid tla-01511c it only stay on for a minute then the screen goes blank. How can I fix this?
  • Anonymous Mar 30, 2014
    There is no sound on Polaroid flat screen tv
What process do you have to go through when typing in the codes?
Do you hit enter after each code and then pwr or just enter after each code or do you hit dash after each code?
Posted on Jun 22, 2008
Posted on Dec 20, 2007
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Posted on Dec 10, 2007
Sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Jan 09, 2010 | Televison & Video
No sound
Hi my name is Eric,
I hope I can help you with your issue ,
Make sure in both the TV and cable box remote that the audio is set to stereo not SAP
SAP is for secondary audio program
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Sep 29, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-01511C
Tried to use my TV as a computer monitor. When tries to boot up, will go to "No Signal". All hooked up correct. Is ther something I need to do tobe able to use the monitor with my computer. I have a Dell Desk Top Computer.
Jun 16, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
Dec 21, 2007 | Samsung SyncMaster 17 in. LCD Television
Polaroid TLA-01511C TV
Go into your menu settings and change from TV to cable...
Dec 08, 2007 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Television Logo
1,036 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
