Question about Frigidaire Refrigerators
Door will not shut properly
The door will not shut properl. You have to push it really hard
    Scholar:
  • 117 Answers
Sometimes doors can getted warped. One trick is to tortion the door in the opposite direction by holding the bottom of the door with your leg and twisting the top with your hands. Sometimes you may have to loosen the liner screws under the door seal to make this work. Hope this helps
Posted on Jul 29, 2009
Refrigerator door seal has gap, and the alarm keeps going off
My refrigerator as delivered had noticeable gaps in the sealing gasket. The solution is to adjust the doors to eliminate the gap. The door hinges allow for adjustment by loosening hardware, adjusting, and tightening hardware again.
Sep 09, 2012 | Samsung Refrigerators
Hotpoint wm64s indicating door not shut program will not function cus door light flashing...however door iis shut n wont open
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
All should be OK going forward
Jul 04, 2011 | Hotpoint WMA64 Front Load Washer
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
We just replaced a broken spring (re[laced both sides) on craftsman garage door opener and now the door won't shut all the way. It goes down to about 12" from closing and then goes back up.
YOU COULD HAVE THE WRONG SPRING OR NOT ADJUSTED PROPERLY. YOU COULD HAVE AN OPERATOR ADJUSTMENT PROBLEM.
HOW DOES THE DOOR WORK MANUALLY??
IF IT IS HARD TO PUSH DOWN AT THE BOTTOM - SPRING PROBLEM - IF IT WORKS AND CLOSES VERY SMOOTHLU AND EASILY THEN YOU COULD ADJUST THE DOWN SENSITIVITY - JUST A LITTLE.
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Craftsman Liftmaster
Check your door springs. One of them is most likely broken and is what caused your drive gear to strip in the beginning.
Jun 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dryer drum won't start unless I manually push start the drum,  then it'll run fine. Turning the start knob just sounds like it want's to start. So right now I have to hold the start button, hold the...
unfortunatly it is either the motor or the drum bearings in the machine. if it is really hard to push i would suggest looking at all the bearings the drum rides on otherwise it is probably the motor that is getting weak.
Jun 08, 2009 | KitchenAid KEYS700LQ Electric Dryer
Computer turn on and Restart Problem.
Are you pushing on the hard disk?
this is a hard disk, are you pushing on the hard disc or on the case of the computer? if your pushing on the case of the computer then most likely the power or reset switch is loose or broken.
do you get a blue screen or what happens? are you really pushing on the hard disk? if your really pushing on the hard disc I would suggest to replace the hard disc to one that doesn't need to be pushed and works properly,
Apr 27, 2009 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Refrigerators Logo
44 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
