Question about Frigidaire Ovens
Frigidare double oven model feb755cebg, display is out. there is power to the unit
RJTech
  • 32 Answers
SOURCE: oven
There may be a fuse gone the oven works on 230 volts there also may be another fuse box under the oven behind a drawer or behind the oven. if all of that checks out ok, it sounds like you may need a new E.R.C. that would be the clock and control board. If all of your fuses and breakers are ok it would be best to have someone from Sears to look at it.
Posted on Dec 17, 2007
SOURCE: DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Posted on Dec 19, 2007
rylee_smith
  • 8619 Answers
SOURCE: my frigidare oven is displaying f3.
Hi
Error F3 means Oven Temp. sensor is short. Check for shorted wire and/or connections between the EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks Rylee
Posted on Mar 30, 2009
EllaWatson25
  • 725 Answers
SOURCE: Need Chambers Oven clock/timer unit, model #GBO-244
I can get you one. Please call me at 9728590929 and I will be happy to find one and ship it to you. Hope this helps! Ella
Posted on Aug 22, 2009
SOURCE: Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Posted on Oct 12, 2009
WHY IS MY DOUBLE OVEN BEEPING WHEN TURNED ON AND THEN DISPLAYS F1 ERROR CODE?
It means you have lost power. It could be due to a power outage or brownout. Check the user interface, control board, harness, etc. It may also have a short. In that case, consult a professional to check the unit.
Dec 30, 2014 | Kenmore 41389 Electric Double Oven
Frigidare double wall oven, both heating elements not getting hot.
Check the mains voltage at the socket it may be blown fuse or faulty circuit braker, If ok check the oven on off switch for voltage.
Nov 26, 2014 | Frigidare Ovens
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Have a Frigidare custom imperial double oven, built in, 60-70's. Bottom oven unit went out sometime ago. now my top broiler unit went out. do they still make those units???
I doubt if they still make that model, but the repair parts should be able to be found and ordered. If you can find the equipment id tag on the unit and write down the model number from it, then you can search for the parts.
Most likely you have either switch problems or the heating element and now the broiler element problems.
Sep 19, 2011 | Ovens
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
DISPLAY ON FRIGERDARE STOVE DOES NOT WORK
HI. Kindly unplug the unit for five minutes. Once the five minutes are up, simply re-connect power to the unit, and try to start a baking cycle. If the display continues to not function, this will confirm that the main control board has failed.
This type of failure will require you to replace this damaged control board, asap.
Dec 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
