Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Dryer knob does not control times or cycles
Put duet electric dryer through diagnostic test.dryer knob i.e. delicate fluff,air only,casual etc does not function.Dryer stays at heavy duty.Light flashes on this .Can not get to do any other functions.I can control up or down time 25,40,59 minutes.
  • 82 Answers
I can be either the timer , control board or check to see if there is a wire brush runing on the drum this is a sensor and if it is worn down it give funny readings
Posted on Jul 29, 2009
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
that knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
Jan 29, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer run but does not heat
Chedk your breakers the dryer will run on 110v but wont heat
Nov 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My maytag model mdg9206bww dryer will not shut off on permanent press or delicates, it will dry somewhat but the unit never shuts off, if I put it on timed air fluff, the timer goes and it shuts off...
When was the last time you got your ducts cleaned? If they r full of lint then the moist air never gets outside and stays in the machine hence the clothes never dry. Might not solve the issue but they need to be done as they r also a fire hazard.
Aug 18, 2012 | Maytag HYE3657A Electric Dryer
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore dryer model # 11067072600 I am getting a F40 error code after 3-4 minutes in any cycle and then the dryer stops. I have checked all connections & continuity. During the diagnostics test mode...
i would have to guess that its a problem with the control board. if it were the user interface it would most likely fail right away and not after a few minutes.
either one are expensive, but the board should cost about 120 bucks
Mar 13, 2010 | Dryers
Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Dec 16, 2009 | Whirlpool Dryers
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
May 09, 2009 | Whirlpool LEQ9858P Electric Dryer
Washing Machines Logo
106 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
