Question about Cell Phones
Audiovox cdm-9155-gpx stopped charging battery from ac power plug or dc power plug.. batteries are good, chargers are good.. can the small batt inside-inside the cell phone carcass be replaced ....
Hi There, I have a HP Pavilion ZE4900 and recently the AC plug in won't work. I have taken the battery out and put it in another comuter that is the exact same and it charges fine, I put my battery in the...
If your computer won't charge the battery, but the battery charges fine in another computer, and you are sure that the charger is good, then your problem is probably the DC power jack. If you wiggle the end of the power cord where it attaches to you laptop, and it starts charging properly, then the DC power jack is broken.
Apr 26, 2010 | HP Pavilion Ze4900 Notebook
The battery will not charge unless the computer is off. it runs on the battery even if its plugged in why? if i unplug the the adapter then plug it in it charges for a few seconds and then stops and then...
1. First remove the Battery, clean the Battery contacts with the pencil eraser and insert the Battery in the Computer.
2. Connect the AC Adapter (Battery charger) securely to the Computer and the Power outlet.
3. If the issue persists, try connecting the AC Adapter to different Power outlet.
4. Make sure that both the connecting points (DC IN port on the Computer and the Power outlet plug) are securely connected and not loose.
5. If the issue persists, try with different AC Adapter.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | HP Pavilion zd8000 Notebook
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
How do you charge it
to charge the GPX ML6488 MP3 Player, you have to find the AC Charger design for GPX then locate the power outlet for GPX then plug the exact or match connector from your charger then plug the AC Charger to the power outlet then wait the MP3 's battery become full.
thanks
Sep 14, 2009 | GPX ML648B MP3 Player
My battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
My camera has just stopped working, will not turn on but is fully charged
YOUR CAMERA CPOUOLD HAVE A BLOWN FUSE ON THE DC/DC CONVERTER BOARD IN THE CAMERA OR THE BATTERY COULD BE BAD EVER AFTER YOU CHARGED IT .
Nov 28, 2008 | Cameras
When i plug in my charger to my laptop it doesnt work and i dont know whats wrong with it
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
2.- Battery is bad
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 14, 2008 | Computers & Internet
Battery problem...
2.- Battery is bad.
Solutions:
2.- Battery is bad
Pablo
Oct 14, 2008 | Dell Inspiron 6000 Notebook
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
