see this causes:
I can not understand your problem exactly, however i will give you the 2 possibilites:
1) water is not entering to the machine:
a) valve inlet water, can be defective test see how
b) float switch defective, is located in the floor of the diswasher see how to test.
2) water is not drain to the machine:
drain line/ air/gap is clogged repair see the diagram
b)propeller pump defective, see the diagram and replace
c)DRAIN valve/ or solenoid elecric defective repair or replace.
d)belt is broken, replace
e)motor can be defective, try to turn manually, if does is o.k otherwise is defective, replace.
f)timer defective, try to clean, loose wires, broken or open repair, If does not replace.
