Question about Admiral AW22 Top Load Washer
My Admiral washer is leaking from the bottom of the machine. I bought this washer over 3 years ago. What can I do now? Thank you for your time. Ben Cai (916)-689-9025
The hoses to the water pump are not tight enough.
Posted on Aug 29, 2009
Admiral washer leaks from bottom
likely if water in center of washer than drain pump , or hose
Oct 16, 2014 | Washing Machines
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
We have a 5 year old front load whirlpool duet washer that leaks & floods and has since we bought it. We had it replaced within a year of purchase, but it continues to leak & flood even with a new...
Due to the fact that you have had two different machines with the same problem seems to rule out a problem with the machine itself. Inspect the drain system that the machine discharges into. I have seen washers that have pumps which can overwhelm the house drain--the cure was to increase the machine's drain spout outer diameter with duct tape until it was a tight fit into the house drain. This prevented water overflowing from that point. The better cure would be to increase the drain pipe size, but that can get pretty expensive. Hope this helps!
Nov 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
Washing machine leaking from underneath. All the connections from the back are secure but water appears to be leaking from the bottom. The leak started almost 24 hours after the washer was used. The...
I had the same problem. I have tried replacing the spring clamp on the drain hose with a regular adjustable hose clamp I got from the hardware store. Not real happy with this situation since I just bought this washer two years ago to replace a previous Kenmore washer that we had for nearly 20 problem-free years.
Apr 07, 2010 | Whirlpool Inglis IP4400 Washer
Washer
Sounds like the top seals are worn, drum needs to be removed to replace top seals (2 off), job for skilled person.
Oct 24, 2008 | Admiral AW22 Top Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Admiral Washer Model#LNC6762B71
if water leaks in the tub your water valve need to replace. and thelower bearing. i can let you know how much the parts are.and valve is not hard to replace but bearing is
Feb 18, 2008 | Kenmore 23822 Top Load Washer
Admiral AW22 Top Load Washer Logo
461 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
