SOURCE: ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
SOURCE: converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie SAT while holding SAT press
ON-OFF key(button) for three seconds until all of the components light
up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your
component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE
STORED.
Hope this works
SOURCE: program my zenith converter box to my tv
while holding down the tvs power button push the channel up or down slowly. this will turn your tv off when your code is found. when it is found and your tv goes off release the power button. now your remote will work with your tv...........
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable. The Installation Guide should appear. The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
SOURCE: Zenith mbr3447 code for magnavox converter box?
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
if your none of the codes work for you cable box then your SOL. try programming your cable box remote for your tv instread.
Have zenith converter box and a. Direct tv remote how do I get remote to work the converter box !! Thanks for any help ....
