Question about Samsung HL-P5063W 50" Rear Projection HDTV
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need to just replace the Fan? Sounds like fan is rubbing on housing or bad bearing. TV 4 yrs old. I have a neighbor with same TV and same age and it just started doing the same thing this week.
  • 28 Answers
The problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Posted on Jul 29, 2009
Hlp5063w lamp and temp lights blink and tv doesnt turn on
Look at turn on to see if lamp fires even for a second.
If lamp has not been replaced in 2,000 hrs it is a suspect.
If you heard a high pitched whine or fan like noise before the set failed remove the lamp and look where it faces----is the color wheel shattered or missing pieces?
Apr 11, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung hlp5063w dlp tv. 1- loud buzzing noise coming from the left side of the set (looking from the front). When I tap it the noise tends to go away and come back. So I'm thinking it's...
It is much more likely considering all these the wheel fails to be your issue.
The problem is often described as a fan like or high pitched sound which since the motor on the wheel turns at over 12,000 rpm is likely to be the cause.
Hint: most color wheels if you listen from the rear when the set is shut down the whine/fan noise instantly slows down until the wheel stops.
Eventually wheel will seize up and shatter and set will not come on.
Mar 18, 2012 | Samsung Televison & Video
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Got a new lamp tv works great but wen I turn it off it has a very quiet hum is this normal also wen I turn it off the.red.light blonks green for a while befor eventualy going away what dose this mean...
Hello; The noise when turning set off is likely the fan that cools the lamp down gradually. The lamp can crack if the fan does not work. Dust in the fan can also add to the noise. When the set is turned on, the microcomputer watches the lamp come up to full brightness and shows this with the LED colors. All lamps containing mercury take time to get up to full brightness.This also applies to mercury compact florescent lamps, yard lights, and even neon signs that contain mercury.
Jun 07, 2011 | Toshiba 52HM95 52" HDTV Projection...
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Replaced lamp on samsung hlp5063w set still broke fan is definatly not running cant find replacement fan
You can get the replacement fans for your samsung at the following link. www.tvrepairworld.com you can call them to see if they have them, But they should they dont list all there parts only the high demand items are listed.
Dec 23, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Noise from tv
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Jul 10, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
1,316 people viewed this question
Henry  Thomas
Henry Thomas
