Question about HP Computers & Internet
Zero wireless configuration has been disabled on presario
Zero wireless configuration has been disabled on my compaq presario and I don't know how to enable it. How do I enable the zero wireless configuration?
  • JBGreenLV May 11, 2010
    Which operating system is this? XP?
    President:
  • 2,666 Answers
Assuming you are on XP then
Click start/run
Type in services.msc
Click OK
The services dialogue will appear. If it helps maximise the screen. Scroll down to
Wireless Zero Configuration and select it. It should show you if it it is strated/stopped or disabled. Right click and select properties in the drop down menu for start up type select automatic underneth in service ststus select start.
In Vista I believe you can get to the control panel where services are found in administrative tools if Vista doesn't have the start/run facility.
Posted on Jul 29, 2009
  • HP Master
  • 497 Answers
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
How do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
Mar 12, 2013 | Acer Aspire 5536-5224 Notebook
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
Compac presario cq56-115dx hp wireless assistant does not work
You don't need HP wireless assistant. You can remove it and enable windows zero wireless configuration to manage your wireless signal. Easier, and less complicated. Message me back to get instructions.
May 17, 2011 | Compaq Presario CQ56-115DX Laptop
Wireless network compaq presario f700 not working
hmm..ok..open start control panel wireless configuration check to see that you're enabled. then back to control panel, network config or settings(depending on which operating system you use) right click on wireless icon, and repair it. let me know if this helps.
Nov 29, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario drops internet connection
Try this....
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 13, 2009 | Compaq Presario Notebook
I have a compaq presario 700 I turned on my computer an the wireless connection no longer works my light stays orange regardless where i move the switch when i asked for a diagnosis the computer tells me...
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Oct 12, 2009 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario v6000
Look in control panel - system - under hardware tab the : Device manager. in there is the network adapters open it from + sign and check is the cross marged on wireless driver if yes then its disabled u can use right mouse button to enable it
also you can find this thing under my network connections look is the wireless disabled or enabled if its disabled use right mouse button to enable it.
If it was helpful rate fixya
Dec 27, 2008 | Compaq Presario Notebook
Wi-fi WPA2 Support?
Try doing the following:
1.) Go to Start -> Control Panel -> Performance and Maintenance -> Administrative Tools -> Services.
2.) Scroll down to Wireless Zero Configuration, and double-click Wireless Zero Configuration.
3.) On the General tab, after Startup type, change the startup type to Automatic.
4.) Start the service by clicking Start.
Let us know if this works, and good luck!
Nov 28, 2008 | Compaq Presario 2598Us Notebook
HOW TO CONFIGURE WIFI WITH Compaq Model C765TU in XP
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 29, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
189 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
