Question about Mitsubishi WS-55807 TV
I turn on the tv and it shuts off after a couple seconds
I tried to turn on tv and it just shuts down off by itself after a couple seconds. had a technician look at it and said it would cost a lot to fix and it wasn't worth the money. tv is about 10 yrs old. technician says it happens all the time with this model after about 10yrs
  • 28 Answers
If you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Posted on Jul 29, 2009
Hello, My ws 55807 flashed 3 times when I plug it in. It seems to be working fine at the moment, but it was shutting down after a couple of seconds a couple of months ago when we were still trying to use it. I gave up on it and thought I would try it again. Please help.
Posted on Oct 14, 2009
Check for bad pico fuses. i picked up a FREE ws-55807 on craigslist a couple weeks ago that didnt work. found two bad fuses changed them and tv work like new.
Posted on Dec 08, 2009
SOURCE:
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tele will not stay on
The tv has an error code thats its way of telling you there is something wrong so it shuts itself down to protect itself. I would have it looked at or call philips and they can tell you what that means. hope that helps.
Aug 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Mitsubishi WS-55807 TV Logo
676 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
