Question about Black & Decker St7000 13'' Automatic Feed Trimmer/Edger
The auto feed feature is not working - Black & Decker St7000 13'' Automatic Feed Trimmer/Edger
Auto Down window feature stopped working. Any ideas?
Try calibrating first,window up & hold switch for 3-4 seconds window down hold 3-4 seconds then back up & hold 3-4 seconds,check for the auto down to work if not then most likely the master switch is needed.
Oct 10, 2015 | Chrysler PT Cruiser Cars & Trucks
Auto feed doesn't work
Take the end apart and make sure the line is not getting bound up or is not over filled to where it can not move freely
Nov 09, 2013 | Homelite 14 in. 5 Amp Electric String...
Having a problem with my stitches being consistent, even when leaving it on the auto feature. at my wits end, can't even sew a straight line without this happening. Has anyone else had this proble
I would use Singers Contact Us, and see what they can tell you more.
Maybe there is a problem with the feed dogs moving properly?
Have you watched the distance they move?
Is your material slippery or something like vinyl? If it's a material that catches on the foot you will have problems, so a teflon foot or a roller presser foot will help.
Feb 22, 2013 | Singer Confidence 7467 Mechanical Sewing...
How to multiple pages scan in pdf by samsung scx-4521f
Try installing this and using the auto-feed feature to create multiple pages. If not using Windows there is another program called Imagejack that will work for Linux, Mac,etc.
Hope this works for you
http://wareseeker.com/Graphic-Apps/image-anvil-2.0.5.zip/10503
Dec 08, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Printing
In the print menu, you will see a Settings or Properties where you can set your paper feed as manual or auto. It looks like you have set it up for manual feed. so you have to go back to that settings and change the paper feed to auto.
Hope this will work for you.
Good luck
luciana44
May 04, 2010 | Brother MFC-6890CDW Printer
Hp 3015 auto feed
You'll have to replace the feedroller kit. Partnumber CB414-67918. Gerrit Jan
Nov 04, 2009 | HP LaserJet 3015 All-In-One Printer
The Auto-On switch does not work. I have to manually turn the shredder on and then feed paper into the slot. It feeds and shreds the paper just fine, but I have to manually turn it off to stop it. All of...
There must be an auto-on/off sensor in the middle of the paper entrance slot - either mechanical or optical.It needs to be cleaned from any obstructions like paper chads or paper dust.It this doesn't help,the sensor maybe defective and it needs to be replaced.
Oct 02, 2009 | Fellowes Powershred SB-87Cs Shredder
The auto feed on a 625 works then it dont, I
I had a 625 chipper several years ago with the same problem. It was just that the engine rpm was to slow sometimes. I don't remember exactly what it needed to be but I think it was around 3500 rpm.
Sep 25, 2009 | Garden
Faulty lens renders auto features kaput on D80
This is a common known problem with the 18-135mm Kit lenses that come with the D80's, and D90's for that matter.
All you need to do is rotate the lens ever so slightly to make the connection, and you may need to turn off the camera and turn it back on. This solves the problem for about 90% of my clients.
Dec 30, 2008 | Nikon D80 Digital Camera with 18-135mm...
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Black & Decker St7000 13'' Automatic Feed Trimmer/Edger Logo
444 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
