Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have a problem with white depost on black clothig after final spin in my new eco top loader
My fisher&paykel gw712 top load wont drain out,is there a filter,
Posted on Aug 08, 2009
  • 82 Answers
It is either he detergent or limescale got to espares and but the lime scale and gunge remover
Posted on Jul 29, 2009
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
My Samsung SWT5V9W top loader spins when you turn the power button on. It still spins during the cycle and 'fights' itself to agitate. Would this be a computer issue?
This can be related to a mechanical issue, Check for free movement of the drum and shaft. check the mountings of the motor,check the suspension and finally the level of the machine, use a rubber mat if the machine moves around.
Jan 23, 2013 | Samsung Washing Machines
I want the washer to fill it up but it goes to final spin
Is it a front loader or top loader? It almost sounds like a front. If so, you have a malfunction in your control panel. You will have to have GE do a test on the circuitry to verify that that's what it is. But if it's a top loader, it most likely has a mechanical timer. If THIS is the case, there's a chance that someone tried to do a second final spin then interupted it before it was done and threw the cycle off. My parents had a HOTPOINT that did that. Just set the timer to the desired starting point, and let it run from there to the end (UNINTERUPTED). This will reset it. Any more problems, let us know.
Dec 16, 2009 | GE Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
Feb 24, 2009 | Maytag PAV2300 Top Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Final Spin Cycle Amiss
depending on the make and the model, especially if it is a top loader, try replacing the belt. when the belts get older they stretch and slip a little, just enought o cause your problem
Oct 10, 2007 | Washing Machines
Washing Machines Logo
225 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
