Question about Sony Cyber-shot DSC-W80 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
  • Sony Master
  • 586 Answers
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Posted on Jul 29, 2009
I have Sony cyber shot DSC W70 every time I turn it on ,it beep and access...then it said to turn power off and then turn power back on
Posted on Jul 30, 2009
4 Suggested Answers
SOURCE: Sony Camera DSC-W30
Shoot 10-15 times hard thats all..
Posted on Jun 15, 2008
SOURCE: Sony Cybershot dsc w55 Access Problem
I was ready to throw the Damm thing.. tried pulling on the lens.. no good.. but banged the bottom of the camera on the table and it worked!!!! Started out softly and increased the banging and it real really worked.. Sony needs to get their act together... this is serious business..
Posted on Aug 26, 2008
SOURCE: error message
AHHH OMG IT FRICKEN WORKED! I SMACKED IT COUPLE TIMES ALL AROUND HAHAHAH. i hope i didnt damage it more. but heyyyy its taking pictures now!!! wooo!!! i soo happy!!! JUS GIVE UM SOME GOOD DIRTY LICKENS AND GIVE UM SOME GOOD SMACKIN!!! HOPE U GUYS HAVE LUCK WITH DAT TOO!!!! AHHH I SO HAPPY I TRIED DOING EVERYTHING I POSSIBLY COULD! AND LOOK WAT HAPPEN! DA FUNNIEST SOLUTION WORKED FOR ME!!!!
GOOD LUCK EVERYONE!
Posted on Dec 05, 2008
It put access than after it starts beeping and appears turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Dec 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
I turn my PS3 on and the screen is always blank. I tried holding the power button for 5 seconds as per the manual and this doesn't help, nothing happens. I also tried entering a safe mode but I can't as I...
I recommend you try to access Safe Mode again.
The way I understand it, your ps3 is supposed to turn off after the third beep as you keep holding the Power button. Then you start the sequence again, and this time you will get the double beep.
Of course, Safe mode is only available for PS3's with system software of 2.60 and higher, perhaps yours is older than that?
I hope that helps.
____________________________________
Sony PS3 Safe Mode
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Turn on the power and the camera beeps 3 times?
hmmm... accesses the card ok? 3 beeps on a computer is a memory thing... might try a differnt SD card... Otherwise, probably is trash, cameras are so cheap that having a shop repair them is just not worth it.
Peace,
Mar 28, 2010 | Samsung S85 Digital Camera
Upon power up, display screen says 'access', lens goes in and out several times and then the camera beeps and display says 'turn the power off and on again'
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 06, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
ACCESS???
1. Please make sure that you're using a fully charged battery.
2. Please try Initializing the Camera. To initialize the Camera.
First, press the Menu button on the Camera to display the Menu items.
Then, select the SETUP option under the Menu.
Then, select the SETUP1 under the SETUP.
Then, select the Initialize under the SETUP1 option to Initialize the Camera.
If the issue still persists, then try Power Resetting the Camera.
First, turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the Power switch for 30 seconds.
Then, reinsert the battery pack into the Camera and turn ON the Camera.
If the issue still persists after performing the steps provided above service of the Camera is required.
Jun 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
'access' Problem
Hi, I just fixed my daughters camera w/same problem.....I read on another site that you squarely hit it on table while holding in hand....I didn't have to slam it just one slightly firm hit and it works fine now...been broken for weeks and tried resetting and pulling battery to no avail...the hit works! viewing screen side is the side I hit on table, only had to do once, and not that hard.(camera was less than 2yr old dsc-70) good luck!
Oct 21, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Camera will not go past this mode.
Firmware problem. Check your Manuel for fault types contact Sony Tech support Team
Jul 11, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
539 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
