Question about Delphi Roady XT XM Radio Receiver
"Antenna" Appears on Roady XT Display
The word "Antenna" always appears on the display for my Roady XT. I got a new antenna and it didn't fix the problem. It's not DirectConnect and it's a work van so I can't mount anything permanently anyway. Another thing I noticed is that the option to change the frequency for the fm transmitter disappeared from the menu.
Any help would be greatly appreciated.
  • 1 more comment
  • lagosalado67 Nov 25, 2007
    I just bought an Xpress XM package and there is no menu for fm transmitter on the radio. It talks about it in detail in the manual but it is nowhere to be found on the radio menu.
  • De2483 Dec 04, 2007
    I periodically have the same problem. It starts up like it is going to load the station, but then only displays "Antenna".
  • jonw145 May 11, 2010
    What is this "Internet Refresh" for the XM Roady xt?
I had the same problem, it says antenna when you turn it on. It seems that there is a small wire that stays in the radio side of the socket right in the middle of the socket. This fine wire breaks off . I think there is no known repair for this. I took a piece of fine wire from a wire brush, and poked it into the socket . Had to get one that was thick enough to stay. Then I plugged the antenna into it, it worked.
Posted on Dec 18, 2007
I have a Roady in my car and recently I have been getting "no signal" and "loading" on the display....I moved the antenna to the center of the roof but it hasn't helped...Could my antenna be bad? Is there...
It is surely the antennae. I have had to replace mine a few times too. The thing is, where it bends, like near the plug connection and near the actual antennae wire connection, it just fractures a bit and that's it.
Pick yourself up a new one on eBay or Amazon, and no, there aren't really heavy duty ones and that wouldn't fix it, it is the wire getting worn.
Apr 02, 2010 | Delphi Roady XT XM Radio Receiver
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at
Feb 07, 2009 | Delphi Roady XT XM Radio Receiver
Antenna message on roady display
I have the same problem. I hooked it up to a different antenna and it works
Nov 04, 2008 | Delphi Roady XT XM Radio Receiver
Roady xt
I have the same problem... I found using a new cradle solved the problem.
Mar 18, 2008 | Delphi Roady XT XM Radio Receiver
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
576 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
