Hardware & Accessories Logo
D
Daphne Phillips Posted on Oct 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a manual ISG12010 GEYSER TIMER,AND HOW DO YOU SET THE TIMER TO ONE OF THE PROGRAMS
Gene Haynes
Level 3:
  • Hardware & A... Master 5,391 Answers
  • Posted on Nov 02, 2017
Gene Haynes
Level 3:
Answers
5391
Questions
0
Helped
2606344
Points
14124
Attach a photo ... or Numerous timer manuals appear on following link that might apply to your Geyser:
http://waterheatertimer.org/Woods-timers-and-manuals-old.html#PB
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1 Related Answer
Anonymous
  • Posted on May 27, 2012
SOURCE: manual for programming digital geyser timer Top Tronic IEC 60730
How to se time
How do I set the timer on an Ellies geyser timer to save electricity
South Africa?
You will need to check your electricity bill and look for the hours when electricity is the cheapest. Se the timer for all those hours. You may need a 1 hour boost mid way through peak pricing.
https://www.fixya.com/support/t27036331-m_desperately_looking_manual_isg1201
Where do i connect the geyser load wire to a dhc15a-20a timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
The other terminals are NO NC and Com
Neutral does not connect to these... only Hot
Hot connects to Com... and then connect wire to geyser to the NO contact... general illustration on link above
15helpful
3answers
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
How to set geyser timer
How to program elc 1001 load control timer
Geyser timer stopped working
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
1helpful
Need to know how to program merry brite digital indoor timer?
Merry Bright digital looks same as GE 15057 and Westek TE55WHB timers
To identify your timer see following two links:
http://compare.ebay.com/like/260679690470?
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Add a comment if this is not your timer.
Here is Westek TE55WHB manual.
Read manual for full information.
http://waterheatertimer.org/pdf/WESTEK-TE55WHB-manual.pdf
Here are instructions taken from manual.
To set current time:
Hold down CLK button and then push day hour and min button until current time shows.
To program:
Press PRG button until 1 and ON display.
Press day hour and min button to set program1 ON
Press PRG button until 1 and OFF display.
Press day hour and min button to set program1 OFF
Press PRG button until 2 and ON display.
Repeat steps to set more programs.
Set up to 7 programs
Programs repeat each 24 hours
When finished, press CLK button and current time displays.
To operate timer: press MODE button.
AUTO to run timer functions.
RDM and timer turns on-off at random times.
Manual to override timer functions.
Dec 22, 2010 • Garden
How to set timer for aqualight digital power center.. it has 7 time cycles per day but do i need to set all 7 cycle and if now i do i set it..
With digital Zilla timer, you can set from 1 to 7 programs.
You can set one program, and that's it, or set 2 programs or 3.
Up to 7.
Open following link to identify timer and download manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
