Question about House Brand Aqua-Pure AP102T Whole House Water Filter System
How do you replace the gasket in the head which is leaking whether on or off thanks
I have a 2001 2.2L gt pontiac sunfire.im wondering what could cuase coolant to leak from the bottom of the intake manifold. That's where it semms like its leaking from because its coming from above the...
you could have a bad intake gasket that is allowing coolant to go into oil. if the head gasket is good then the other thing it could be is a crack in the engine.
May 06, 2014 | Cars & Trucks
Car with blown head gasket more that 120,000 miles
Quite possibly the motor will be OK after replacement of one or both head gaskets. This can be done with the engine still in the car. The definitive tests for whether this is needed are a compression test (shows head gasket leaks) and a radiator leak-down test (shows water jacket coolant leaks).
If it turns out the job is required it is a good idea to have the timing belt and water pump replaced also, and the crankshaft nose and camshaft oil seals. The cylinder head faces and mating block faces must be carefully checked for flatness.
Although more expensive it is advisable to specify genuine Toyota seals and gaskets as the cheaper non-genuine ones do not last on this engine.
The V6 has several characteristic oil leaks which develop, and that may not be related to the head gasket problem. It will leak from
- rear bank cam cover gasket, onto the exhaust- distributor shaft o-ring seal- oil filter bracket o-ring seal (if present)
These can be replaced at the same time.
The alternative is to have a 2nd hand motor fitted, which is always an unknown, but if you can get a warranty that will be better.
Get several quotes for each alternative, and try to gauge the reputation of the mechanics
http://www.cartalk.com/content/mechanics-files
May 14, 2012 | 1993 Toyota Camry V6
Fix head gasket
For leaking head gasket it has to be replaced. For head gasket leaking and other troubleshooting, there are help links provided. Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
This will help. Thanks.
Feb 27, 2012 | Renault Cars & Trucks
Oil leak from head gasket can it be replaced
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------How to replace head gasket on car? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket? http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century? http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
Should I only replace head gaskets or complete head gasket assembly? http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak? http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
---------Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket? http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
---------This will help.Thanks.
Jan 30, 2012 | 2006 Scion tC
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Replaceing head gasket
Jan 28, 2012 | 2002 Kia Sportage
Head gasket
Jan 27, 2012 | 1992 Plymouth Voyager
I have a honda civic ex i will like to know how to change the head gasket whether i have to remove the engine from the car
Dear Sir,
For replace head gasket you no need to remove engine you can replace gasket there only but you have to remove cylinder head and do head facing and then put it back with new gasket thanks.
yogesh
Jan 30, 2011 | Honda Civic Cars & Trucks
Blown head gasket
Depending on the size of the leak theragasket may work. There are other products that add to the anti-freeze, if it's anti-freeze that is leaking. Some add to the oil. For a temp fix I would and have been able to prolong a head gasket replacement. But it's just a temporary fix. Could last 1 week, 6 months or not at all.
A head gasket replacement is not a easy job, messy if you do it and a little costly if a shop does it. I've been there, Good luck
If you like this advise, please do the rating - Thanks
Oct 17, 2009 | 1988 Ford Escort EXP
Daihatsu charade 1.3 1996 model. I bought the above car 3 weeks ago from a car dealer in WA. A week later the radiator overheated and has done so twice since. The thermostat has been changed twice but has...
In its simplest terms, the head gasket is the spacer/insulator between the cylinder head and the engine block. When the piston (in the block) moves upward to compress the air/fuel mixture (against the cylinder head), tremendous pressure develops inside the combustion chamber. The pressure will find any easy means of escape to expand. If the gasket is defective, the pressure will pass through that gasket and enter the water jackets (where the collant flows through). The pressure/air bubbles will ride the coolant flow and eventually end up inside the radiator and would then be visible as you have posted.
Incidentally, the gasket may be OK but the cylinder head could be warped and the same fault would also be exhibited. This is especially more so on aluminum heads.
Both the gasket problem and/or the warped cylinder head could have resulted from a prior overheating problem.
Corrective procedure on the air bubbles would require top overhauling wherein only the cylnder head is removed. Of course once removed, your mechanic would be able to inspect the pistons and its sleeves and could decide if a general overhaul is required or stick to the cylinder head work. A top overhaul also requires cylinder head gasket replacement.
Unto the overheating problem, you may want to check the water pump, thermostat, fan, fan relay and fan clutch. It may also be to your added advantage if you would have the radiator flushed/cleaned as well as the water jackets. Some mechanics especially in warmer regions opt to completely remove the thermostat and permanently wire the fan to always be on.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | Daihatsu Charade Cars & Trucks
House Brand Aqua-Pure AP102T Whole House Water Filter System Logo
57 people viewed this question
Top House Brand Garden Experts
Dennis Key
Dennis Key
john h
Are you a House Brand Garden Expert? Answer questions, earn points and help others
